PLEASE HELP! URGENT
jack_zxr400
PostPosted: 20:03 - 13 Mar 2009    Post subject: PLEASE HELP! URGENT Reply with quote
Sorry this in wrong section, need as much help as poss,
This is Jacks girlfriend,
his bikes broken down on the M25
between junction 9+8 (nr dartford)
for hours, can anyone help
with what he could do to start the bike:
bike started loosing power
pulled over
bike cut out
could not start it,
petrol fine, electrics work (neutral light comes on)
when tries starting, misfires, good compression but
wont start.
ANY FEEDBACK HELPFUL!
really desperate,
many thanks
Jodie
Previous Bike: ZXR 400
Current Bike: R6
Test Date: 8/8/2008-PASSED
tutton
PostPosted: 20:08 - 13 Mar 2009    Post subject: Reply with quote
Was it wet roads? or damn conditions,
water in carbs or airbox often makes bikes not start and just keep backfiring.
OssY
PostPosted: 20:12 - 13 Mar 2009    Post subject: Reply with quote
Wat year bike???
If it was wet it could also be the coil or the plug cap has got wet and is shorting.
If someone could get some WD40 down to him he could spray the inside of the plug caps and then see if it runs.
jack_zxr400
PostPosted: 20:16 - 13 Mar 2009    Post subject: Reply with quote
thanks so much, its not wet roads,
the bike is h100 1991
thankyou thankyou thankyou
other suggestions really appreciated!
as road is not wet,
jodie.
Current Bike: R6
Paddy Blake
PostPosted: 20:18 - 13 Mar 2009    Post subject: Reply with quote
It could have water in the bottom of the carbs.Drain them and try again.
I take it he tried push starting it.
Paddy.
jack_zxr400
PostPosted: 20:20 - 13 Mar 2009    Post subject: Reply with quote
Hes just gone off the phone to me to try push starting it again,
and i told him to check the carbs, but he says he
doesnt think he can because he doesnt have
the right tools.
Thanks for suggestions,
will answer r.e push starting when he calls back,
but i dont think it will as hes already tried Sad
Thank you Smile Jodie
Current Bike: R6
PostPosted: 20:21 - 13 Mar 2009    Post subject: Reply with quote
Checking then changing the sparkplug would be my first port of call.
Making sure the plug lead is screwed in properly.
If it has points ignition, making sure the points haven't closed up.
jack_zxr400
PostPosted: 20:22 - 13 Mar 2009    Post subject: Reply with quote
wont push start Sad soundec like it might but
didnt spark, then made poof sound
thanks jo.
Current Bike: R6
jack_zxr400
PostPosted: 20:25 - 13 Mar 2009    Post subject: Reply with quote
"Checking then changing the sparkplug would be my first port of call.
If it has points ignition, making sure the points haven't closed up."
checked plug lead, doesnt know how to check ignition points, and
cant check sparkplug
thankyou! jo
Current Bike: R6
tutton
Without tools there aint going to be much else he can do at the roadside,
Needs to ideally plug out and check sparks, check fuel on plug, then check the igntion timing as per stinkwheel says.
Paddy Blake
PostPosted: 20:26 - 13 Mar 2009    Post subject: Reply with quote
Make sure the battery leads are tight.
Paddy.
jack_zxr400
PostPosted: 20:27 - 13 Mar 2009    Post subject: Reply with quote
Sad oh dear,
how do you check ignition points?
can it be done without tools?
ty, jo Smile
Current Bike: R6
jack_zxr400
PostPosted: 20:28 - 13 Mar 2009    Post subject: Reply with quote
he cant get to battery leads, but ty paddy,
there under seat and he doesnt know how to
lift it up ty jo Smile
Current Bike: R6
Paddy Blake
PostPosted: 20:33 - 13 Mar 2009    Post subject: Reply with quote
What bike is it
jack_zxr400
PostPosted: 20:35 - 13 Mar 2009    Post subject: Reply with quote
h100 f 1991 :s !
ty jo Smile
Current Bike: R6
Selkie
PostPosted: 20:40 - 13 Mar 2009    Post subject: Reply with quote
Silly idea but why not call the RAC/AA get the bike home or somewhere safer to work on it than the hard shoulder of the M25.
Did he manage to get it started in the end?
jack_zxr400
PostPosted: 20:42 - 13 Mar 2009    Post subject: Reply with quote
No, its not started, and he isnt a member!
I think hes arranged to be picked up,
but that will be some time, hes just trying to
see if theres anything he can do meantime
thanks Smile
Current Bike: R6
The Artist
PostPosted: 20:53 - 13 Mar 2009    Post subject: Reply with quote
I suggest not to keep trying with throttle open. Probably flooded (popping noises suggests this)
Check all electrical connections.
Check water reservoir, make sure it hasn't lowered by much
Check underneath engine for any obvious leaks or damage.
jack_zxr400
PostPosted: 20:58 - 13 Mar 2009    Post subject: Reply with quote
Thank you, I will pass on the message when he calls back
in a sec, I think hes close to giving up, me too,
noise of the traffic is giving me ear ache! haha.
Thanks Smile really appreciate everyones suggestions, Jo.
Current Bike: R6
jack_zxr400
PostPosted: 21:02 - 13 Mar 2009    Post subject: Reply with quote
Thanks, might be flooded, he'll have to see at home.
thanks again Smile jodie.
Current Bike: R6
PostPosted: 21:40 - 13 Mar 2009    Post subject: Reply with quote
Tell him not to go out on a 2-stroke without a spare sparkplug and a plug spanner again. 9/10 times a stroker conks out it is a problem with the plug.
Many of them even have a place to keep one under one of the panels/the seat (the H100 isn't one of them though). The kawasaki triples have spaces under the seat for two sets of spare plugs.
jack_zxr400
PostPosted: 22:01 - 13 Mar 2009    Post subject: Reply with quote
Thanks for the advice
and to everyone thats posted,
hes on his way home soon
with the bike Smile
So im sure he'll have a look
when home what the issue is
and moan thoughrly soon Laughing
Thanks again for the help,
Sorry to be a pest!
Jodie Smile
Current Bike: R6
The last post was made 17 years, 198 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.15 - MySQL Queries: 13 - Page Size: 119.56 Kb
