Anyone into single speed/fixed gear bicycles?
PostPosted: 20:11 - 13 Mar 2009    Post subject: Anyone into single speed/fixed gear bicycles? Reply with quote
I'm not but I think one would be a good gift for my girlfriend. She does a lot of miles on her pushbike (like she'll ride 20 miles across town to go to work in the morning) and she NEVER changes gear with the result that the springy bits on the gears get all gummed up with crap and I have to keep fixing it for her.
I kind of half mentioned the subject of fixies, she recoiled in horror at the idea of a true fixed wheel bike but a freewheel single speed would be ok. I believe the way to do it is to fit a thing called a flip-flop hub which allows you to choose either system anyway?
So, I'm off round the second hand bike shops this weekend to look for an older racer bike frame with horizontal dropouts. Anything in particular other than this I should be looking for?
I was thinking of painting it all up nice and basically building her a bike from parts around the frame. Nothing rediculously expensive or flash so it doesn't get stolen from outside her work first time out.
Am I setting myself up for failure here? Any pitfalls to avoid?
Pernig
PostPosted: 20:24 - 13 Mar 2009    Post subject: Reply with quote
I'd recommend a bike with a Sturmey Archer enclosed hub. They've been around for years with not much change in the design, so, although I wouldn't attempt to fix the hub myself, parts are quite readily available.
I used to have a fold-up bike when I was about 15 that had 20 inch wheels and a 3-speed hub (never needed to change as where I lived was very flat, but it was a nice luxury if I ever needed to get up a hill). I never even oiled the chain, even after a massive downpour which flooded my road, which I decided to ride through. That was great fun Laughing.
My Dad thought it would be funny to chuck it on a skip one day. I really miss that bike Crying or Very sad.
H100 Breaking for spares
PostPosted: 20:25 - 13 Mar 2009    Post subject: Reply with quote
I'd be tempted to get a Sturmey Archer 3 speed hub; ratios are 3:4 1:1 and 4:3, so you still get the flexibility of dropping a cog on hills.
cagiva gezzer
PostPosted: 20:29 - 13 Mar 2009    Post subject: Reply with quote
As above. 3 speed hub.
You can convert normal freewheel hubs to single speed. Such as - https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=300286676183&cguid=ce63f17b11c0a0aad3463b26ffcd412c
PostPosted: 20:38 - 13 Mar 2009    Post subject: Reply with quote
Sheldon Brown's site is a great resource for all things cycling :-
https://sheldonbrown.com/fixed/index.html
WildGoose
White Van Man
PostPosted: 20:48 - 13 Mar 2009    Post subject: Reply with quote
I rode a BMX to school for a couple of years, good few miles each way, obviously it was just single speed, tension adjusters just like a motorbike.
Bit cramped when sitting down. but the gearing itself was never a massive inconvenience, and chain coming off was basically unheard of.
I have never owned a geared bike that all gears engaged smoothly on, didnt get a constant clicking from somewhere, or would randomly get confused when changing gears and sling the chain off. The chain slipping between cogs when you put heavy pressure through the pedals (up a hill say) was also a favourite, would often chuck you off as all resistance is suddenly removed.
Granted i've never bought expensive pushbikes, but I've hated most of my experiences with them with a passion! Hateful things.
I'd definately be interested in a single speed pushbike if I didn't live in the hills where I do.
PostPosted: 21:35 - 13 Mar 2009    Post subject: Reply with quote
Aye, 3-speed hubs are one way, but I'm more meaning a racer bike with a single sprocket (a bit like they use on a velodrome but with lower gearing) the aim being to keep both the weight and the pedalling resistance to an absolute minimum.
Vin
PostPosted: 09:21 - 14 Mar 2009    Post subject: Reply with quote
Why not show her the advantages of changing gear? It's not exactly difficult and she'll probably get everywhere more quickly.
Itchy
PostPosted: 10:07 - 14 Mar 2009    Post subject: Reply with quote
You could always get her a shaft drive bike, the gearing is limited though but as with shaft drive motorbikes with sealed drive system there is no chain or sprockets to worry about. I believe you can even retrofit them onto chain bikes.
Strong thigh muscles enough to crush your pelvis Wink
D O G
PostPosted: 14:15 - 14 Mar 2009    Post subject: Reply with quote
Are there no hills in your town?
Single speed bikes look lovely, and would be great in a pancake town like that London, but anywhere with gradient they would be a nightmare.
I'm guessing she rides in a stupidly low gear all the time. The lowest I have on mine is a 38-27, the highest a 52-11. I use both of those every day, couldn't cope with anything much different.
PostPosted: 14:44 - 14 Mar 2009    Post subject: Reply with quote
Nope, she lives in York and she rides an old falcon racer bike with a frame that is FAR too big for her. It never, ever goes out of top gear.
When I say she does distance, she'll go 40 miles in a day just going to work and back. She also does triathlons for fun, on the self-same bike. A fixie would be easier to pedal, I was going to gear it the same as her current bike.
Azonicben
PostPosted: 15:56 - 14 Mar 2009    Post subject: Reply with quote
Most hubs can be set to singlespeed with the addition of a spacer kit, on my singlespeed mountain bike I use 39-14/15/16 depending where I'm going.
Other thing get a Brooks leather saddle it'll take a while to bed in but. For distance they are the ultimate in comfort it'll mould to your arse shape and supple up over time.
And finally rear brake only and narrow 12-15inch flat bars
And you should end up with a courier bike, google courier bike for tips I would link but I'm using my phone.
Hth
The last post was made 17 years, 230 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 77.63 Kb
