| s44678 |
 s44678 Guest
 Posted: 12:44 - 16 Mar 2009 Post subject: Getting a rounded bolt out |
Rounded off a bloody axle clamp bolt didn't I...
So anyway would this technique work for getting it out?:
It's an allen key type, with a like a tapered cap head on the bolt, so I was thinking I could use a hacksaw to cut a groove across the bolt then use a flat-head screwdriver to get it out?
Or any other ideas? |
| Tristan. |
 Tristan. World Chat Champion
 Posted: 12:49 - 16 Mar 2009 Post subject: |
Lol, kawasaki.
That should work fine, alternatively (this only tends to work on larger ones mind) you could hammer in a 1 size up allen key or an imperial one if you can find one.
heat on the fork bottom and penetrating fluid always help  |
| s44678 |
 s44678 Guest
| Mudskipper |
 Mudskipper World Chat Champion
| s44678 |
 s44678 Guest
| yen_powell |
| BanditsHigh |
 BanditsHigh Worse than a woman
 Posted: 13:37 - 16 Mar 2009 Post subject: |
As mentioned above a torx bit is best ... it'll be easier to hammer in as you have less metal to 'shift' out of the way (six points) unlike a hex bit (six flats) and it'll grip just fine.
The hacksaw/screwdriver would also work but give you less metal to lever against compared to the torx.
As a last resort, weld another bolt onto it and use that to undo it.
Hope you get it sorted  |
The last post was made 17 years, 157 days ago. Instead of replying here, would creating a new thread be more useful? |
