Getting a rounded bolt out
s44678
Guest
PostPosted: 12:44 - 16 Mar 2009    Post subject: Getting a rounded bolt out Reply with quote
Rounded off a bloody axle clamp bolt didn't I... Doh!
So anyway would this technique work for getting it out?:
It's an allen key type, with a like a tapered cap head on the bolt, so I was thinking I could use a hacksaw to cut a groove across the bolt then use a flat-head screwdriver to get it out?
Or any other ideas?
Tristan.
PostPosted: 12:49 - 16 Mar 2009    Post subject: Reply with quote
Lol, kawasaki.
That should work fine, alternatively (this only tends to work on larger ones mind) you could hammer in a 1 size up allen key or an imperial one if you can find one.
heat on the fork bottom and penetrating fluid always help Thumbs Up
s44678
Guest
PostPosted: 12:53 - 16 Mar 2009    Post subject: Reply with quote
Yeah yeah! I'm a cock I know.... Had to start with bike DIY somewhere didn't I! Just happened to be on my actual bike rather than a project!
So get some WD40 in there first? How much heat on the fork leg? (don't want to cock it up even more)
Mudskipper
PostPosted: 13:11 - 16 Mar 2009    Post subject: Reply with quote
I'd hammer in a torx bit rather than an allen key. I got a cheapy set of 6 bits for a quid to do just this on a rounded master cylinder cap bolt. Thumbs Up
s44678
Guest
PostPosted: 13:17 - 16 Mar 2009    Post subject: Reply with quote
Is that not best for slightly bigger bolts though? Where you have a bit more bolt 'meat' to whack the oversize torx bit into? Don't want to strip it again and leave nothing there.
yen_powell
PostPosted: 13:20 - 16 Mar 2009    Post subject: Reply with quote
Cut a slot then use an impact driver with a slotted bit so you get it out in one go.
XT1200Z and a DR350 in bits
BanditsHigh
Worse than a woman
PostPosted: 13:37 - 16 Mar 2009    Post subject: Reply with quote
As mentioned above a torx bit is best ... it'll be easier to hammer in as you have less metal to 'shift' out of the way (six points) unlike a hex bit (six flats) and it'll grip just fine.
The hacksaw/screwdriver would also work but give you less metal to lever against compared to the torx.
As a last resort, weld another bolt onto it and use that to undo it.
Hope you get it sorted Thumbs Up
The last post was made 17 years, 157 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 48.47 Kb
