CBR600 losing power at high speed
T0MMY
PostPosted: 00:10 - 17 Mar 2009    Post subject: CBR600 losing power at high speed Reply with quote
My '96 CBR600 sometimes stutters and loses power when I'm going along at motorway speeds on a constant light throttle. It'll just suddenly hesitate and then pick up again a second later. I was thinking fuel starvation or some kind of problem with the direct air induction system? Seems to be worse when I've just been spanking the bitch and then started cruising along.
Any other ideas before I start taking her to bits?
ZX6R + CBR600RR
OssY
PostPosted: 00:13 - 17 Mar 2009    Post subject: Reply with quote
Any mods??
baldy
PostPosted: 00:32 - 17 Mar 2009    Post subject: Reply with quote
My xr does this after long periods at the same revs. I just ignore it.
(Not much help)
One day i will rule the world, just not today.
T0MMY
PostPosted: 19:17 - 17 Mar 2009    Post subject: Reply with quote
Totally standard apart from stainless downpipes (still has original silencer).
ZX6R + CBR600RR
nowhere.elysium
The Pork Lord
PostPosted: 21:00 - 17 Mar 2009    Post subject: Reply with quote
Silly as it might sound, is the airbox intake totally clear? If there's a small obstruction, it could just be that once you're moving at a certain speed, it displaces enough air to mess up the proper flow into the intake.
T0MMY
PostPosted: 22:22 - 17 Mar 2009    Post subject: Reply with quote
It is externally and the inside of the airbox was clear last time I had it open but I'll have another look.
The problem goes away instantly if I open the throttle a bit more though.
ZX6R + CBR600RR
nowhere.elysium
The Pork Lord
PostPosted: 10:55 - 18 Mar 2009    Post subject: Reply with quote
Fuel flow, then? Are the carbs clean?
Blue_SV650S
PostPosted: 11:11 - 18 Mar 2009    Post subject: Reply with quote
Sounds like a partially blocked breather to me ...
DaveH
PostPosted: 12:57 - 18 Mar 2009    Post subject: Reply with quote
Shifty CARB ICING!!!!
Well someone had to say it sooner or later! Wink
https://www.timhastingsracing.co.uk/
ZX7R & ER6F
ssray
PostPosted: 19:52 - 18 Mar 2009    Post subject: Reply with quote
mine had a build up of crap in the float bowls, take em off and check
The last post was made 17 years, 202 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.78 - MySQL Queries: 15 - Page Size: 63.18 Kb
