| kawashima |
 kawashima World Chat Champion
 Posted: 15:13 - 17 Mar 2009 Post subject: Dirty oil makes clutch slippy? |
My W650's clutch is slippy now. It slips when I open wide in 5th or 4th gear. But not in 1st gear .
I adjusted clutch wire but it's still slippy. I phoned and asked the mechanic, he asked me if I haven't changed oil for a long time. Yes, I've ridden 3000km after oil change, a little bit longer than usual.
Does dirty oil makes clutch slippy?
I have once burnt my clutch and changed them to new ones in Dec. 06. ____________________ own:2020 Serow 250
owned: 2012 YB125SP, 2008 TDM900, 2005 W650, 2002 LS125R, 2002 CB400SF, NS50F, C50 / Trip to UK(2009), Hokkaido touring(2013) |
| stinkwheel |
| kawashima |
 Posted: 15:33 - 17 Mar 2009 Post subject: |
Thank you for letting me know! ____________________ own:2020 Serow 250
| kawashima |
 Posted: 16:17 - 17 Mar 2009 Post subject: |
I'm going to change oil this weekend, and adjust clutch wire (crank case side), try to bring biting point more closer to the handle bar.
But if they don't solve the problem, what should I do?
What I'm feeling is W650 doesn't have strong clutch springs from the original... ____________________ own:2020 Serow 250
| stinkwheel |
 Posted: 16:48 - 17 Mar 2009 Post subject: |
Sometimes the brand of the oil can make a difference. It may be worth trying a different brand.
If you have a service manual, the free length of the clutch springs and the thickness of the plates can be measured to check they are within tolerance.
Sometimes the surface of the clutch plates can become "glazed". They can be removed and lightly rubbed with fine abrasive paper to remove the glaze. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 17 years, 228 days ago. Instead of replying here, would creating a new thread be more useful? |
