Dirty oil makes clutch slippy?
kawashima
PostPosted: 15:13 - 17 Mar 2009    Post subject: Dirty oil makes clutch slippy? Reply with quote
My W650's clutch is slippy now. It slips when I open wide in 5th or 4th gear. But not in 1st gear Confused .
I adjusted clutch wire but it's still slippy. I phoned and asked the mechanic, he asked me if I haven't changed oil for a long time. Yes, I've ridden 3000km after oil change, a little bit longer than usual.
Does dirty oil makes clutch slippy?
I have once burnt my clutch and changed them to new ones in Dec. 06.
own:2020 Serow 250
PostPosted: 15:24 - 17 Mar 2009    Post subject: Reply with quote
Should be the opposite. Old oil is less lubricating.
A slipping clutch will make your oil dirty more quickly.
kawashima
PostPosted: 15:33 - 17 Mar 2009    Post subject: Reply with quote
Thank you for letting me know!
own:2020 Serow 250
kawashima
PostPosted: 16:17 - 17 Mar 2009    Post subject: Reply with quote
I'm going to change oil this weekend, and adjust clutch wire (crank case side), try to bring biting point more closer to the handle bar.
But if they don't solve the problem, what should I do?
What I'm feeling is W650 doesn't have strong clutch springs from the original...
own:2020 Serow 250
PostPosted: 16:48 - 17 Mar 2009    Post subject: Reply with quote
Sometimes the brand of the oil can make a difference. It may be worth trying a different brand.
If you have a service manual, the free length of the clutch springs and the thickness of the plates can be measured to check they are within tolerance.
Sometimes the surface of the clutch plates can become "glazed". They can be removed and lightly rubbed with fine abrasive paper to remove the glaze.
The last post was made 17 years, 222 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 45.3 Kb
