Optimate connection to Cigarette lighter socket?
AngelGrinder
PostPosted: 15:59 - 17 Mar 2009    Post subject: Optimate connection to Cigarette lighter socket? Reply with quote
I remember seeing sometime a socket that would allow you to plug a cigarette lighter socket into the lead coming off my battery for my optimate charger....
Any idea what this lead is called....and anywhere I can buy it from? Ideally a shop that I can go to, rather than order online.
I can't find it on Maplin, but I might be being stupid....
NSR Mick
PostPosted: 16:27 - 17 Mar 2009    Post subject: Reply with quote
One of these?
https://www.maplin.co.uk/Module.aspx?ModuleNo=1055
Bikeless
PostPosted: 16:33 - 17 Mar 2009    Post subject: Reply with quote
You would need a converter from 12V to 240V.
binge
Emo Kiddy
PostPosted: 16:35 - 17 Mar 2009    Post subject: Reply with quote
I know what you mean. Not sure of the lead actually exists though. You may have to buy some new connections for your optimate and go form there.
From what I gather. You have a hard wired input socket for your Optimate charger. So you just remove the seat or whatever, And plug the optimate in.
When you unplug your optimate, I am guessing you want a lead with a Cig lighter socket on one end, And an Optimate socket on the other end. So you can plug it into the socket which is hard wired to your battery. TO save you running 2 lots of wiring from the battery?
binge
Emo Kiddy
PostPosted: 16:36 - 17 Mar 2009    Post subject: Reply with quote
Eh? Eh?
mikeoldcars
ive got one of these https://www.accumate.co.uk/it020007.htm
binge
Emo Kiddy
PostPosted: 16:37 - 17 Mar 2009    Post subject: Reply with quote
mikeoldcars wrote:
They do exist then.
Ben
Bikeless
PostPosted: 16:45 - 17 Mar 2009    Post subject: Reply with quote
Eh? Eh?
Sorry,i thought you meant you were trying to power your optimate from your car to charge a bike,my mistake, Embarassed
AngelGrinder
PostPosted: 17:57 - 17 Mar 2009    Post subject: Reply with quote
Thats the lead I want, cheers for the help.
I'm going away tomorrow though...I'll just have to borrow sockets in Cafes I guess!
theopj
PostPosted: 17:59 - 17 Mar 2009    Post subject: Reply with quote
I've got one on my bike as well. They work pretty well although bit difficult to mount (ended up using cable tiles on mine and attaching it to the yoke). Also the 1st one I had got all corroded inside and the bottom section inside became loose so I had to bin it. Also the lead could do with being a bit longer - mine doesn't quite reach back to the battery compartment.
Anywhere that sells Optimates should be able to sell them - I've seen them in Streetbike before.... although more pricey than online even after the postage was applied.
Do a search on TM68 Optimate and your see lots of places selling it.
Suzuki Bandit SA 1250 & Honda CB750F2T
sickpup
Old Timer
PostPosted: 23:40 - 17 Mar 2009    Post subject: Reply with quote
Will be finding out this weekend if I can get the parts to make these cheaply.
kawakid
PostPosted: 00:44 - 18 Mar 2009    Post subject: Reply with quote
Why bother?
They are always going to be live?
I'm presuming like my Accumate, it is wired direct to the battery (and its what you leave connected for easy charging of battery).
If you buyt that cable and leave your sat nav/phone charger on its going to drain your battery if you leave your bike without unplugging it.
Why not buy a car cigarette lighter extension for about £3 from a local car shop and a relay for about £2.
Simply cut the insert that goes in to the cigarette socket and throw away and the rest ie (the female cigarette lighter end) rig up to the relay. Yeah it'll take about 30mins more time to do, but won't ever drain your battery.
I've a twin and a 4.
PostPosted: 01:03 - 18 Mar 2009    Post subject: Reply with quote
I just stuck a random 2 pin plug on some leads coming off the battery to charge it, then stuck a similar socket on the trickle charger. I stuck the normal clips on with one of these plugs too, which has the added bonus that I have done similar on the pump which has long lost it's clips.
Peirre oBollox
PostPosted: 10:43 - 18 Mar 2009    Post subject: Reply with quote
These are what I use
https://www.maplin.co.uk/Module.aspx?ModuleNo=11455
1 is male the other is female
Blue_SV650S
PostPosted: 11:17 - 18 Mar 2009    Post subject: Reply with quote
Yep. That's exactly what I did, the RC connectors are the same as those used in the Optimate ...
So basically all you need is one of these (I actually took mine off an old RC car Embarassed) the lighter socket and a bit of wire, solder it all up and you have what you need for <£5!! Smile
https://images.maplin.co.uk/full/gz98g.jpg
The last post was made 17 years, 197 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.31 - MySQL Queries: 13 - Page Size: 86.19 Kb
