DISASTER!
spitfire123
PostPosted: 19:06 - 19 Mar 2009    Post subject: DISASTER! Reply with quote
Well the mito has thrown somthing else at me again....
this time it apears to have a lot of gearbox oil all over the bottom of the engine Confused
and all this in JUST 800 miles of riding.
so what should i do?should i buy a gasket se of rthe WHOLE engine and get it all over and done with? i acturly realy dont want to do it because the bike has been fully rebuilt 800 miles ago Confused
my question is how hard is it to dismantle the WHOLE engine and replace all the seals and parts? easy?
i found this complete seal kit on ebay which i thought was a reasonable price: https://cgi.ebay.co.uk/Cagiva-Mito-Complete-Gasket-Set_W0QQitemZ280275287216QQcmdZViewItemQQptZUK_Motorcycle_Parts?hash=item280275287216&_trksid=p3286.c0.m14&_trkparms=72%3A1121%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318]
will that be okay for it?
btw its a 1999 EVO 1 mito
the tally now stands at:
-Engine rebuild
-Replacement shock (as a berk on here sold me one that had nothing in it!if you have one PM ME)
new speedo(anyone have one?PM ME)
and powervalve pully spindal (if anyone has one sparePM ME)
cheers
You won't be able to eat my dust......As it'll settle before you get there.
PostPosted: 19:16 - 19 Mar 2009    Post subject: Reply with quote
First of all, is it the gasket? Are you sure the sump plug hasn't just rattled out?
If it is the gasket, I wouldn't get a gasket set, I'd be using a cereal box and making my own. Why change all the gaskets when only 1 has failed?
Tricolor
PostPosted: 19:37 - 19 Mar 2009    Post subject: Reply with quote
My bet would be that the oil seal on the selector shaft or output shaft has gone. I had to replace a selector shaft seal the other week on a Cagiva.
Disassembling the engine is easy enough with the right (sometimes wrong) tools. Takes an afternoon to take apart and rebuild.
It's really overkill to replace every seal and gasket, unless it's the crankcase gasket, in which case you may as well do them all and change the bearings while your at it.
Give me ambiguity or give me something else.
spitfire123
PostPosted: 22:30 - 19 Mar 2009    Post subject: Reply with quote
hi mate,
you mean the gear selector shaft?
im pretty sure i cheched round the outsdie of it and it was all okay....no leaks
it defo look like its coming from the crank gasket as its only at the bottom of the engine and knowwhere else?
ill check now....
spitfire123
PostPosted: 22:31 - 19 Mar 2009    Post subject: Reply with quote
no to the cerial box idea thanks....no affence.
and id change the rest seeing as its apart anyways Smile
cheers
spitfire123
PostPosted: 22:35 - 19 Mar 2009    Post subject: Reply with quote
hello mate,
just went outside(in the dark) and shoved my hand in where the gear selector joins the casing....its totaly dry from what i can tell.
does that seal come in that gasket set i posted for the selector shaft?
as i orderd it a little while ago.
and does anyone know where i can get the ally round spindal from for the powervalve unit?as my powervalve is now jammed because the cable is binding as its so worn on the noggings Confused OR DOES ANYONE HAVE ONE SPARE, because i cant find any?
also need shock...
cheers Thumbs Up
Tricolor
PostPosted: 00:06 - 20 Mar 2009    Post subject: Reply with quote
spitfire123 wrote:
hello mate,
Yes, it looks like there is an oil seal for the selector shaft in that set.
From what you say it's leaking crankcase gaskets, but check the clutch cover gasket too. you'll need to split the engine to replace the crankcase gasket. Take a look at this helpful thread at 125ccsportsbikes.
[EDIT] The seal isn't in that set.
spitfire123
PostPosted: 20:49 - 20 Mar 2009    Post subject: Reply with quote
Tricolor wrote:
spitfire123 wrote:
hello mate,
hello again mate,
at work today i took part of the fairing off and the tank.....
the oil soaking the bottom dosent appear to smell?like gearbox oil does....
someone at work said it could be oil/petrol leaking from the carb?
i touched the carb and it was wet underneeth and a bit oily.....could it have run down underneeth?
i never turn my fuel tap off...maby this is the problem? Confused
hopefully it is as i realy dont want to splint this engine when its just been done!
cheers Thumbs Up
P.S
does anyone know where i can get a powervalve pully spindal from!!!!? i cant get one anywhere...as the one on my powervalve(on engine) is worn!
Finglonga
PostPosted: 17:29 - 21 Mar 2009    Post subject: Reply with quote
Why not clean it all off with gunk and then look where it is originating from.
If it is fuel then it will be eating away at the paint on the engine cases anyway.
Andy Sez....
F.Y.Y.F.F.
The last post was made 17 years, 179 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 65.8 Kb
