help needed on rollers and Variator spring kits.
Jack2004
PostPosted: 22:12 - 20 May 2004    Post subject: help needed on rollers and Variator spring kits. Reply with quote
First of all sorry for re-posting.
Right i need some help on rollers, my ped at the moment had 17x12 at 6.6g, i am wanting to upgrade these to either 4.5g, 5.0g, 5.6g or i could get 3.4g, which of these would be best?
Also i am going to get a Variator spring kit, they come in +15%, +22% and +30%, which would be best to get out of these?#
Hope someone can help
Sparks!
Sir Tart-a-lot
PostPosted: 22:14 - 20 May 2004    Post subject: Reply with quote
https://www.bloomcounty.org/~megan/misc/pancake_bunny.jpg
PsychoHippy
Jammy Git
PostPosted: 23:14 - 20 May 2004    Post subject: Reply with quote
Yams - that is the funniest thing I have seen all night! Laughing
I spend all my money on bikes and beer, the rest I simply waste!
PostPosted: 23:25 - 20 May 2004    Post subject: Reply with quote
The cotter pin will need machining to fit the new flange nut. Oh and you'll need to cut down on the gudgeon bearings because they'll overscore if you put too many horses through the sprocket collet.
I am fairly certain that the needle guide springs will need changing too because the cam wheel guides won't work otherwise. Oh and if you pull 6.6 g on a ped then I expect you'll die.
I'm sorry I have no Idea what you are on about. Do you know what a clutch and a gearbox do? Wink
cagiva gezzer
PostPosted: 23:42 - 20 May 2004    Post subject: Reply with quote
Done any other work to the engine?
Springs and rollers are not that expensive, so grab a whole load and don't make too large changes.
For those who don't know, the combination of springs and rollers determins what rev range a engine uses when its fitted with a centrifugal clutch and variator.
bikedudextrm
PostPosted: 00:11 - 21 May 2004    Post subject: Reply with quote
What ped is it Question .
Police Tut Tut
https://www.bikepics.com/members/bikedudextrm/
PostPosted: 09:34 - 21 May 2004    Post subject: Reply with quote
I suspect he does know what a clutch does, just not the kind you're thinking about. Reckin his does pull 6g or whatever as well... just insider the clutch Smile.
Sparks!
Sir Tart-a-lot
PostPosted: 09:44 - 21 May 2004    Post subject: Reply with quote
I think Mark's last comment was aimed at my attempt at being funny with the bunny pancake picture.
I'm not sure what a clutch does to be honest...
Is it the thing that makes the bike sound lounder?
Can't remember to be honest..........
Hmmm I've stripped loads of clutches @ college, and stripped a ped down too I presume the top thread is about belt sizes/strengths or something but not too sure really but I know what a clutch does Rolling Eyes
PostPosted: 11:12 - 21 May 2004    Post subject: Reply with quote
I was trying to be sarcastic, and pointing out that I don't know how a 'ped twist and go gearbox works (unless its the same as on a Mini Moto).
Also I was suggesting that a bike with a clutch and gearbox might be better? Wink
Sparks!
Sir Tart-a-lot
PostPosted: 11:30 - 21 May 2004    Post subject: Reply with quote
Not sure why, but unfortunately I took the effort at college to learn how a ped clutch/gearbox works.....
It's clever in a way, but completely useless as I won't go near peds.. hehe
I don't know how mini-moto's work but I assume it's the same as peds.
The last post was made 22 years, 136 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 65.94 Kb
