Tyre problems???
craigT19
Jolly Green Giant
PostPosted: 20:40 - 20 May 2004    Post subject: Tyre problems??? Reply with quote
hi,
My ninja keeps wheel spinning when i'm at full throttle in first and second gear, around 8K rpm..... and its getting annoying Sad
Is this likely to be a problem with the bike?? or just that the tyres aren't up to the job? i'm running bridgestone 010's. i've done around 300 miles on them
either way i'm changing them for dragon evos Laughing
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
kev
I Hump Things
PostPosted: 20:44 - 20 May 2004    Post subject: Reply with quote
Unless the roads are very wet of icey there is no way a 600 will spin up a bt010 just off the throttle.
You will find its more like your clutch is slipping.
Lastly bt010`s are stickyer than dragon evo corsas.
20:02:36 Jammy-R6: any holes a goal
20:02:48 kev: even if its a hairy mans arse
20:02:56 Jammy-R6: hell yes
craigT19
Jolly Green Giant
PostPosted: 20:47 - 20 May 2004    Post subject: Reply with quote
well the roads are dry, the bike IS spinning the rear, and there is no way 010's are stickier than pirreli dragon super corsers LMAO!!!
ohh and its a new clutch, which is fine, i know its spinning out cos it happened alot last night whilst i was ridding with scotty_zx6r (pm him if u must), the back kept kicking out on bends.
kev
I Hump Things
PostPosted: 20:48 - 20 May 2004    Post subject: Reply with quote
Evo`s and super corsas are different tyres.
Jon
Anyone for donuts?
PostPosted: 20:49 - 20 May 2004    Post subject: Reply with quote
Sounds like the clutch to me, I'm getting some clutch slip which at first felt like the wheel was spinning up.
craigT19
Jolly Green Giant
PostPosted: 20:50 - 20 May 2004    Post subject: Reply with quote
ok thx jon...ill get it in the garage before i go to france to get it looked at Thumbs Up
Mr C
PostPosted: 20:51 - 20 May 2004    Post subject: Reply with quote
does it spin in a straight line or are you just cack handed coming out of bends with too much gas
do you have any free play in the clutch lever
187.3bhp = 201mph
craigT19
Jolly Green Giant
PostPosted: 21:00 - 20 May 2004    Post subject: Reply with quote
yeah both but i happens mostly when i hit a bump or a cats eye etc...
and i have some play in my clutch lever....
i've spoken to a few guys on Mirc and most seem to think its a suspension problem
billy whizz
PostPosted: 22:46 - 20 May 2004    Post subject: Reply with quote
sounds like a damping problem to me to, get it sorted mate before you get dumped in a ditch. what's probably going on is your back wheel is skipping under power nice light bike plus lots of power needs lots of control!
Here comes the summer! Smile
PostPosted: 23:45 - 20 May 2004    Post subject: Reply with quote
Assuming it isn't the clutch (and when it bites again it could loosen the rear wheels grip) then I would say there is a problem with the rear suspension. Probably lost most of the damping, either compression or rebound (but check nobody has been fiddling with the adjusters), possibly with the spring would up too hard.
PostPosted: 09:37 - 21 May 2004    Post subject: Reply with quote
Hmmmm.
Presuming it is the rear wheel spinning and not the clutch...
Supercorsa's will probably make it a lot worse while the tyre's cold and it's harder to get them warm. So do becareful with the right hand coming out of corners if it's doing it with 010s at the moment.
Demonic69
The Pink Rhino
PostPosted: 10:12 - 21 May 2004    Post subject: Reply with quote
Checked the air pressures mate? Very Happy
Back on a Blade. Just feels so right.
Kris
PostPosted: 13:29 - 21 May 2004    Post subject: Reply with quote
Maybe the garage slotted in a ZX-10 engine by mistake.. Wink
www.prisonplanet.com
Robby
Dirty Old Man
PostPosted: 14:35 - 21 May 2004    Post subject: Reply with quote
Check your linkages - they would have all been undone to be transferred to a new engine and frame, so the shop could have done them up too tight or with too little lube, meaning your shock isn't moving much.
craigT19
Jolly Green Giant
PostPosted: 23:06 - 22 May 2004    Post subject: Reply with quote
G wrote:
Hmmmm.
thx G but i'm only planning on using the supercorsa's whilst i'm in the south of france...were i should be able to get them up to temperature without to much problem Razz
the bikes going in the shop on wednesday, so ill find out if its the suspension then.
The last post was made 22 years, 143 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 85.47 Kb
