Luggage - rate yours here
Kris
PostPosted: 14:42 - 27 Mar 2009    Post subject: Luggage - rate yours here Reply with quote
Got any luggage on your bike?
I'm mostly thinking of hard luggage and top-boxes etc but if you have a set of soft luggage then all well and good too.
So, what do you have and who made it?
Easy to fit? Waterproof? Cheap? Secure?
(I'm looking at top boxes and seen manufacturers liek 'Hepco & Becker' etc that I've never heard of before)
Ta all
www.prisonplanet.com
Flip
PostPosted: 15:03 - 27 Mar 2009    Post subject: Reply with quote
https://www.sounddistribution.co.uk/products.asp?recnumber=2177
Easy to fit, water proof, pretty big, only prob is the logo is starting to peel off, not that I care about that.
Itchy
PostPosted: 15:12 - 27 Mar 2009    Post subject: Reply with quote
https://www.bykebitz.co.uk/acatalog/Buffalo_Soft_Luggage.html
Have had 2 sets of the Touring paniers as above....(Gman destroyed my original set when he crashed).
They are not water proof , even with the rain covers as rain soaks in via the inner side.
They are reverse water proof however ie once things inside them get wet they will stay wet for a very long time.
They are unaerodynamic and cut my tank range from 155miles per tank to 130 miles per tank. Down to 95 to a tank when the rain covers are on.
Rain covers are pants they are flappy , they split and fly off and burn onto your zorst, and when they do work water pools into the bottom of them.
The stitching on the velcro straps is poor very poor they snapped even when lightly loaded with 4 or 5 kilos of soft things like clothes. Thus they need to be supported from underneath and or balanced on the pegs.
Zips on them are poor and as said lightly loaded the zips would seize and or jump teeth..
All this happened in Spain.
They also need the rubber matting and taped up fairings as they will rub through CBR paint.
Quite poor really.
PostPosted: 15:19 - 27 Mar 2009    Post subject: Reply with quote
I've got a Kappa 42 litre topbox on a Givi rack. I believe Kappa are made on the same production line as Givi, might be wrong as I'm not sure where I heard it. The previous owner said he lost one on the motorway where it just came loose so put a bolt through the bottom to keep it on the rack. It does what it's supposed to, keeps my stuff dry.
When I need more capacity I have a pair of Swagman throwovers which are probably 17 years old. Well made and will keep a shower off stuff, but I tend to pack things in binbags when I use them. Not seen them for sale for a while now.
I've also got a magnetic tankbag from Lidl, not really used it in earnest to comment on the long term quality, but so far it's been useful for the clear pocket on top.
metalangel
PostPosted: 15:43 - 27 Mar 2009    Post subject: Reply with quote
Had a Kappa 42 (I think) litre top box on my CB5... did the job, I suppose... it would hold one of those fridge packs of beer, two pints of milk or a loaf of bread and all the other things that your lady will ask to you pick up on your way home. The mounting itself needed tightening every so often but otherwise it was fine.
To be honest, I don't miss having it - a good rucksack'll carry just about the same amount, the only thing I'm lacking is a place to stash the helmet when I go into the shop/etc.
SlimRick
Lidl tank back - big enough for a weeks worth of pants and socks, some work shirts, jeans and a couple of sweatshirts. Too early for long term comments, but seems really weel made and very practical.
LustyLew
PostPosted: 15:48 - 27 Mar 2009    Post subject: Reply with quote
I have the yamaha hard cases for my Tenere. No need for over priced mounting plales or racks. Although they are a bit cumbersome and, whilst waterproof, I think in a serious 'off' they wouldn't look too pretty.
PostPosted: 17:01 - 27 Mar 2009    Post subject: Reply with quote
KTM logo'd Touratech boxes. Very expensive and a little flimsy (has had the bike resting on them a couple of times. To be fair, they are pretty light. Luggage capacity listed at 10kg or something, but I've managed around 20kg, though it did destabilise the bike at low speed (thus ending on it's side as it compressed the suspension too much on the side stand).
Locks are extra and you need two locks per box. Lid doesn't hinge so needs to be fastened at each end.
Fitting was quite easy as stuff was designed for bike.
https://gees.zenfolio.com/img/v1/p636370034-3.jpg
Not worth the money. Next ones will be DIY, I reckon.
Givi top-box with light. This is a cheap 'scooter' top box.
Works quite well, though can be a bit hard to close when I leave my gym stuff in there loose (bits fall between where the top and bottom meet and get trapped) thanks to the 'clam shell design'. Extra brake light is nice, I've added LED indicator strips too now.
Been using this on various bikes for a while and I'm generally happy with it - good value for money.
Can fit a full-face flip-up helmet in, or a reasonable amount of shopping, etc.
It's also quick-release, using a single lock to hold it onto it's base and unlock the top. The bases is easily attachable to a rack - on my zx9 I have made holes in the pillion seat and put some bolts through it.
https://gees.zenfolio.com/img/v0/p224232994-3.jpg
Recommended if the size is right for you Thumbs Up.
cyclops12
PostPosted: 22:38 - 27 Mar 2009    Post subject: Reply with quote
mines for my chair and what ever else i can get on it Very Happy
https://img11.imageshack.us/img11/393/n5125890571315959508693.jpg
hayabusa trike
Flip
PostPosted: 22:50 - 27 Mar 2009    Post subject: Reply with quote
Fair play to ya.
teabag
PostPosted: 23:10 - 27 Mar 2009    Post subject: Reply with quote
Honda (Givi - I think) 35 litre top box. Relatively cheap from Honda official accessory list (£75 including the mount). Sturdy, waterproof and holds lots of stuff including my lid. If I need more space I cargo net a bag to the pillion seat.
NS125R = 2 years > GSX600F = 7 years > XR125L = 3.5 years > SV650S........and a Citroen Synergie HDI for the kids.
Paulington
PostPosted: 00:41 - 28 Mar 2009    Post subject: Reply with quote
No luggage for me, usually just throw a messenger back over my shoulder.
Anything heavier would kill the bike. Laughing
LeeR
PostPosted: 09:24 - 28 Mar 2009    Post subject: Reply with quote
I've got Kappa hard luggage (topbox + panniers) they came with the bike, and in 2002 were the OEM fitment for Suzuki.
As Shaggy said Kappa have actually been bought by Givi now, but the whole range inc the Kappa stuff can be found at Calamander.
They're very easy to fit, with one key for all locks and to remove them from the frame/plate.
Never took the risk waterproof wise as I've got a Suzuki topbox bag for the topbox, and use rucksack liners for the panniers.
I use an Oxford Sports Expanding tank bag £35 secondhand off eBay.
I also have an Ortlieb dry sack for large bulky items, like sleeping bags etc... and this I lash to the pillion seat with a bed roll, also in a rucksack liner.
Everything stayed dry even in the torrential rain of last September.
I think costs were reasonable, apart from the hard luggage which would probably be around £500 all-in.
Here's the bike fully laden:
https://i217.photobucket.com/albums/cc162/lrogers_album/luggage.jpg
My claim to fame: Austin Vince nicked my pen...
kawashima
PostPosted: 12:54 - 28 Mar 2009    Post subject: Reply with quote
I have GIVI E33 and E47.
E47 is wide enough for 2 helmets. But mine is arai tour-x, I can't put two tour-x s in it due to chin part. The height is as same as helmet. I can't load anything under or over the helmet.
E47 is wide. But I don't have to see it on mirrors. When I drop the bike, my bike has engine guard, but it makes a small scratch on E47.
I think why GIVI doesn't make triple width one of helmet is you can't see rear on the mirrors well, and it will break the carrier of top box when you drop the bike.
own:2020 Serow 250
neil.
PostPosted: 13:08 - 28 Mar 2009    Post subject: Reply with quote
I have a Givi E30 which I find to be waterproof and it locks up quite securely. I also fitted the optional brake light to it which is pretty neat IMO. It takes way more than the 3kg quoted maximum load without problems. Thumbs Up I'd recommend it for a small engined scooter or bike anytime.
sagalout
PostPosted: 13:18 - 28 Mar 2009    Post subject: Reply with quote
Got a Givi V46 which I used on the Versys. Very good quality, waterproof, decent capacity (was enough for a 4 day tour including a big SLR camera). Looking for a way to attach it to the 12, but only for longer trips as it doesn't really suit the bike lol.
Also have the Oxford sports luggage which is ok. Waterproof with the rain covers, but quality not brilliant after a few uses. Tankbagespecially lost it's shape, which I replaced with a Hein Gerricke which is much better built.
Current Bike: Triumph Speed Triple T309
Previous: CBR600F => ZX9R => Triumph Tiger => Honda Blackbird => GSXR 750 => Versys =>ZX12R
Finglonga
PostPosted: 13:48 - 28 Mar 2009    Post subject: Reply with quote
Just standard BMW panniers, they do everything I ask of them.
Andy Sez....
F.Y.Y.F.F.
Peirre oBollox
PostPosted: 14:09 - 28 Mar 2009    Post subject: Reply with quote
+1 for Ortleib dry bags
plus OEM triumph hard panniers/topbox, & Bags connection gas cap mounted sports engaged tankbag on the sprint
Toukakoukan
PostPosted: 00:21 - 29 Mar 2009    Post subject: Reply with quote
I've got some Jesse panniers for my F650
https://www.jesseluggage.com/
I can absolutely say they're worth every penny.
Those things can withstand a nuclear blast, in fact I think Indie hid in one of them in his latest movie, it just /looked/ like a fridge.
RTW Motorcycle Blog
The last post was made 17 years, 159 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 108.35 Kb
