Gluing fairings?
MG#43
PostPosted: 15:29 - 28 Mar 2009    Post subject: Gluing fairings? Reply with quote
Hi,
I've got some cracks in my seat unit. I'm hoping gluing them together will sort it, though i'm not sure what glue to use and where to get it from, anyone any ideas?? thanks!
sickpup
Old Timer
PostPosted: 17:15 - 28 Mar 2009    Post subject: Reply with quote
Use Plastech which I should have back in stock on Wednesday.
PostPosted: 18:18 - 28 Mar 2009    Post subject: Reply with quote
Depends how big the cracks are but superglue has never failed me. Get it from your local post office, if they don't have it Wilkinson will.
elgard
PostPosted: 19:39 - 28 Mar 2009    Post subject: Reply with quote
Yeah i use superglue but a good tip for a bit of extra strength is to straighten out some staples and place them along the crack like stitches.
Works for me anyhow.
stirlinggaz
PostPosted: 19:47 - 28 Mar 2009    Post subject: Reply with quote
Hi,
cheap bodge is epoxy resin, from pound shop, or super glue GEL.
but better off using plastech, works well & lasts for ages.
cheers,
GAZ
randyfrog
PostPosted: 21:44 - 28 Mar 2009    Post subject: Reply with quote
If you want it done properly, the plastics can actually be "welded" from behind, although this is normally done in conjunction with a respray.
PostPosted: 23:50 - 28 Mar 2009    Post subject: Reply with quote
From my experience, welding isn't as strong as superglue unless you want to melt holes in your panels.
tutton
PostPosted: 18:23 - 29 Mar 2009    Post subject: Reply with quote
I agree with plastic welding (Done by a professional)
Superglue never worked when i tried it, mainly because its got no flex in it, and cracks really easy.
loply
PostPosted: 21:46 - 29 Mar 2009    Post subject: Reply with quote
Araldite is the normal solution as far as I know.
It resists shocks, is far stronger than superglue (and nowhere near as brittle), and easier then plastic welding.
From my experience welding is potentially unreliable, just use araldite... Get it on ebay, araldite rapid specifically, comes in a dual syriinge thing nowadays.
Yamaha SZR660 Caution to the wind, the throttle pinned!
Zeeky
PostPosted: 09:54 - 30 Mar 2009    Post subject: Reply with quote
ive seen little carbon fiber patches which comes together with araldite!!
the carbon fiber does the same job as the staples!! but better??
it costs around $10 - 20...!!
WoooHooooooooo!!!!!!!
PostPosted: 17:45 - 30 Mar 2009    Post subject: Reply with quote
The proper plastic-weld is better but if you have to use superglue get the stuff they sell in double-glazing shops. It's slow setting and much stronger than ordinary stuff.
alains
PostPosted: 18:01 - 30 Mar 2009    Post subject: Reply with quote
with my long experiency i can tell you nothing will stick on plastic except plastech . even if that hurts my purse nothing can beat this
look at wemoto site and type plastech
Noxious89123
PostPosted: 20:54 - 30 Mar 2009    Post subject: Reply with quote
Really? Confused
My fairing is held together with some fibreglass reinforced plastic that I bought in a box from halfords, works incredibly well. It's just a case of roughing up the plastic wih some sandpaper, and cleaning the area your fixing with some meths to get any greasy muck off. Sticks well Thumbs Up
alains
PostPosted: 22:42 - 30 Mar 2009    Post subject: Reply with quote
obviously fiberglass will stick but how long ?
using this powder & liquid makes the repair undestructable and it's the only way to repair the logs
ZRX61
Victor Meldrew
PostPosted: 01:14 - 31 Mar 2009    Post subject: Reply with quote
alains wrote:
with my long experiency i can tell you nothing will stick on plastic except plastech ....
.. & the same type of plastic applied with a plastic welding thingie Wink
sickpup
Old Timer
PostPosted: 16:56 - 02 Apr 2009    Post subject: Reply with quote
A couple of pictures of old repairs using Plastech.
Keep in mind these repairs are over 4 years old and still holding well.
sickpup
Old Timer
PostPosted: 11:57 - 04 Apr 2009    Post subject: Reply with quote
Back in stock here.
The last post was made 16 years, 318 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 92.42 Kb
