rf600 smoking on acceleration
c_b768
PostPosted: 23:55 - 20 May 2004    Post subject: rf600 smoking on acceleration Reply with quote
greetings all first post have read many topics since joining very good site.
i have a rf600 no problems untill i did a 300 mile trip on it on arriving i noticed my oil view had gone from max to under min i always check before any distance, so topped up and made the trip back same oil usage again.
friend followed me at home and said i was smoking blue when heavy exeleration and overtaking.
am i right in thinking that the piston rings need replacing if so i will need a head gasket as well any tips on where to buy on the net or what else i will need.
any advice greatly received i have just ordered my manual of the chap that runs this site scale 1 - 10 for how easy it is to do (if it is this).
thanks in advance
*********SUZUKI RF600**********
PostPosted: 21:46 - 21 May 2004    Post subject: Reply with quote
Yes, to take the barrels off you will need to replace the head gasket. Don't think Suzuki gasket sets are that cheap.
How much experience do you have in rebuilding engines? What tools do you have?
c_b768
PostPosted: 22:47 - 21 May 2004    Post subject: hi kickstart Reply with quote
be my first engine rebuild but have access to all tools and a good mechanic if i get stuck but would like to attempt this on my own if you know what i mean its never been bored out as far as i know so standard size piston rings should be ok any tips you know or can share.
kev
I Hump Things
PostPosted: 08:39 - 22 May 2004    Post subject: Reply with quote
While you have it apart make sure you change the valve stem seals as well.
20:02:36 Jammy-R6: any holes a goal
20:02:48 kev: even if its a hairy mans arse
20:02:56 Jammy-R6: hell yes
PostPosted: 14:06 - 22 May 2004    Post subject: Reply with quote
With the tools and the help you should be fine. Pick up a Haynes and have a read at what you need to do.
Valve stem oil seals would tend to result in the engine smoking badly when you close the throttle from speed. However they are cheap so you would be best to do those while the engine is apart.
Time for a big bore kit maybe Twisted Evil ?
Demonic69
The Pink Rhino
PostPosted: 14:11 - 22 May 2004    Post subject: Reply with quote
Wanna buy an RF6 Radiator? I think I've still got one lying around Very Happy
Back on a Blade. Just feels so right.
c_b768
PostPosted: 06:55 - 23 May 2004    Post subject: Reply with quote
thanks for the tips and good to use a forum where people actually reply i let you all no how i get on either a nice fixed bike or i be looking here for a new one
The last post was made 21 years, 329 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 51.84 Kb
