how do i make my exhasut less noisey
rockers
PostPosted: 22:51 - 30 Mar 2009    Post subject: how do i make my exhasut less noisey Reply with quote
Hi there people what would guys say would be the easiest way to make my exhaust not as loud ??
So far i can find these db killers you put in the can, but do they make much of a difference ? just seems like a slightly smaller pipe with holes in.
Rocky
B10Hazard
PostPosted: 02:12 - 31 Mar 2009    Post subject: Reply with quote
Expanding foam
Cool
No longer any socks
PostPosted: 04:32 - 31 Mar 2009    Post subject: Reply with quote
Put the standard can on?
paddlesat16
PostPosted: 13:59 - 31 Mar 2009    Post subject: Reply with quote
bag of steel wool, pop around the inside of the can(around the pipe with holes in) wrap with thin wire(picture framers wire etc) should kill the noise Very Happy
I once saw a bloke shagging a donkey.... in Saudi arabia. Theory Test Passed 26/10/09 Mod 1 Passed 26/4/10, Mod 2 Passed 7/6/10 Current Bikes Suzuki GSX1400 K5, Aprillia Pegaso 650, Suzuki DR350T.
rockers
PostPosted: 14:34 - 31 Mar 2009    Post subject: Reply with quote
dont have the standard can, this one was half the price of the original one.
expanding foam - taking the pee Mad
wire wool ? does this work ?
PostPosted: 14:43 - 31 Mar 2009    Post subject: Reply with quote
What sort of can is it?
The db killers do work, but are also likely to eat some of the power.
If it is an oldish race can then the packing might well have compressed. Unrivet the end and take the perforated tube out, then wire some fresh baffle packing round the perforated tube. Put more around the outside and then reassemble it (you can buy the baffle packing). Wire wool can be used as well but glass fibre is probably more effective.
rockers
PostPosted: 15:03 - 31 Mar 2009    Post subject: Reply with quote
this is the one i have https://cgi.ebay.co.uk/SPORT-EXHAUST-CAN-for-KYMCO-Stryker-HARTFORD-VR-125-200_W0QQitemZ380109098924QQcmdZViewItemQQptZUK_Motorcycle_Parts?hash=item380109098924&_trksid=p3286.c0.m14&_trkparms=72%3A1689|66%3A2|65%3A12|39%3A1|240%3A1318
It says it has removable baffle but all it is, is just a bit thats screwed in the end that takes the end of the pipe internal diameter down by about 5mm smaller only makes a small difference.
have repacked the exhaust but am little unsure that i have done it right. ive packed it in not really tight but not so its floating around in there.
PostPosted: 15:45 - 31 Mar 2009    Post subject: Reply with quote
Doesn't look like you can take that apart to repack it (well not without cutting it open and then welding it back up again).
rockers
PostPosted: 16:06 - 31 Mar 2009    Post subject: Reply with quote
oh sorry mine is slightly difference its the older one on the exit end the largest part holds the end on by rivets, as ive said i have repacked it.
Rocky
paddlesat16
PostPosted: 19:16 - 31 Mar 2009    Post subject: Reply with quote
The wire wool does work, used to do it all the time back in the day, but it was standard on old 70's -80s bikes when I first started riding Laughing
rockers
PostPosted: 20:05 - 31 Mar 2009    Post subject: Reply with quote
would wire wool work better than 'proper' exhaust wading ?
PostPosted: 23:23 - 31 Mar 2009    Post subject: Reply with quote
No, proper exhaust packing is much better and it doesn't burn like wire wool.
paddlesat16
PostPosted: 11:51 - 01 Apr 2009    Post subject: Reply with quote
Tis true, it burns... Embarassed also used swarf from work(that doesn't burn) is slightly bigger and longer lasting than wire wool( from my engineering days) Laughing
rockers
PostPosted: 16:06 - 01 Apr 2009    Post subject: Reply with quote
ok well ive repacked it with proper exhaust wading and think i may have packed it to tight as has a harder sound so im guessing its not take much sound out.
Am going to get a db killer friday and 'make it fit' should help a little i guess.
Thanks for the help guys
Rocky
jake_hyo
PostPosted: 19:11 - 02 Apr 2009    Post subject: Reply with quote
just out of interest, is it really that loud to be a problem??
Jake
rockers
PostPosted: 23:30 - 02 Apr 2009    Post subject: Reply with quote
it is pretty loud when its only a 125 and getting anywhere sounds like it'l be rapid but nothing Razz
i had one complaint from someone so must be loud. may try and get a video if mic on camera pics it up ok.
Grav
PostPosted: 23:47 - 02 Apr 2009    Post subject: Reply with quote
One complaint and you change it?
Nay, nay and thrice nay young feller. Only change it if the MOT man says its failed. Wink
Dark Lord Of Custard
snigger..... Very Happy
rockers
PostPosted: 00:52 - 03 Apr 2009    Post subject: Reply with quote
well nothing was said at the mot about the exhaust so take it its fine.
Must admit tho do feel bit silly with all the noise and no go Razz
Mr Hammers
PostPosted: 09:27 - 03 Apr 2009    Post subject: Reply with quote
Bear in mind that louder is also safer. My NSR125 has a very sharp bark (I packed the baffling uber tight) and more drivers knew I was coming when filtering, than the quieter (at low speeds) Bandit.
Next time someone complains, tell 'em it's a Health & Safety thing. Thumbs Up Wink
A Guide To Powerbands
MarkJ
PostPosted: 12:38 - 03 Apr 2009    Post subject: Reply with quote
Never worked for me unfortunately. My Old Millie sounded like the apocalypse (as does the current one Laughing) and some old boy still drove into the side of me, and it was bright yellow!
Proper obs are better than a loud exhaust.
Loud exhausts sound cool though Very Happy Thumbs Up
cyberglass
PostPosted: 13:18 - 03 Apr 2009    Post subject: Reply with quote
One complaint and your gonna change it tell them where to go
The noise is a safety mesure to make sure if a car has not seen you it will hear you Twisted Evil Insurance companys should give us a discount for loud exhausts Mr. Green Mr. Green
AH damn already posted 2 posts up i should read them more Very Happy
DL650 Vstrom 2004
DRZ400S 2003
Yamaha R1 2005
The last post was made 17 years, 206 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 106.79 Kb
