Help with speeding up the healing process (wisdom tooth)
Leggy_Girl
PostPosted: 21:26 - 06 Apr 2009    Post subject: Help with speeding up the healing process (wisdom tooth) Reply with quote
Does anyone have any tips for speeding up the healing process after having a wisdom tooth removed please?
I had my lower right one removed last Monday and naturally i am still getting very bad jaw ache. The stitches are still in (they're dissolvable) and i'm not sure whether the pain is coming from the stitches pulling on my mouth or the gaping hole where my tooth was. Either way the pain resonates through the right side of my jaw/ face, and i liken it to the cramp you get in your calf! So you can probably understand why i'm keen for it to heal as soon as possible!
I know someone will have been through the same, seeing as wisdom teeth are such a pain in the bum!
"One moment can change a day, one day can change a life and one life can change the world." Siddhartha Gautama
PostPosted: 21:30 - 06 Apr 2009    Post subject: Reply with quote
Could try Anbesol, it's a local anesthetic. I used to use it when my wisdom teeth were forcing my jaw apart, and later when I needed root canal.
[edit] Just looked it up, it contains Benzocaine, so you could just chew on a Durex Performa Smile
Leggy_Girl
PostPosted: 21:41 - 06 Apr 2009    Post subject: Reply with quote
I was using Orajel (normal strength and extra strength) in the lead up to it being removed, because that contains Benzocaine too. I've got loads left but i wasn't sure if i should use it seeing as my gum is all exposed and nasty. Would i be ok using it do you think?
Leggy_Girl
PostPosted: 21:49 - 06 Apr 2009    Post subject: Reply with quote
When i read that the first time it didn't even register. As i was closing the thread i quickly clicked back and had to double take! Laughing
PostPosted: 21:55 - 06 Apr 2009    Post subject: Reply with quote
I'd try to avoid putting it in the hole, rather see if applying it low down on the gum has any effect. I'd be more worried that any probing/rubbing in the area will hasten the stiches dissolving.
I found after my root canal that the bigger pain was from my jaw being clamped open for an hour, rather than the actual root work.
When my mother had all her teeth out, she was advised to rinse with warm salt water to speed up the recovery - you might want to give that a try, so that the area is kept clean.
I also found that I was getting crankier as the pain was keeping me awake; dosing up with cocodamol helped alot with that.
Leggy_Girl
PostPosted: 22:06 - 06 Apr 2009    Post subject: Reply with quote
I know exactly what you mean. I've just been taking over the counter pain killers but they never get me through the night. I might go to the docs and ask for some cocodamol (they normally give it to me because of a rib problem i have) as i've run out. It's like i've got permanent pmt where i'm increasingly tired Laughing
I'll also try the salt water rinsing. Cheers! Thumbs Up
tatters
Exxon Valdez
PostPosted: 22:21 - 06 Apr 2009    Post subject: Reply with quote
Your lucky its just the one, l,ve got to have all four removed under a general next month Confused
Leggy_Girl
PostPosted: 22:32 - 06 Apr 2009    Post subject: Reply with quote
Mines just the one for now. They're keeping an eye on the other 3 Sad
Tatters, have they all impacted or something? Let us know how you get on when you've had them out. I can't imagine having 4 out in one go! Shocked
And make sure they do give you a general. They said mine would be done like that and changed their mind on the day. They gave me 3 dirty great injections instead. Never want that again!
MaybeGuy
PostPosted: 23:45 - 06 Apr 2009    Post subject: Reply with quote
4 cocodamol
2 paracetamol
3 codeine
wake up in 2 days.
tatters
Exxon Valdez
PostPosted: 23:48 - 06 Apr 2009    Post subject: Reply with quote
One is upside down and the other three are at a 90 degree angles facing forwards, was going to have only one removed as it was starting to rot from trapped food but when l had the x-rays at hospital they wanted to take all of them out.
No way l,m having them taken out while awake could,nt image having teeth pulled Sick , had two pre canine teeth pulled under a general a few years ago.
PostPosted: 01:05 - 07 Apr 2009    Post subject: Reply with quote
warm saltwater...gentle rinsing..as often as you you stand it.
Its natural,quick and should of been recommended on your post op factsheet thing.
Pat
Suitor_Stu
PostPosted: 09:50 - 07 Apr 2009    Post subject: Reply with quote
Hey, as you are probably aware these things do take a bit more time to heal than normal extractions. From what you are saying it sounds very much like the pain you are getting is mainly from your jaw muscles having been held open for a length of time? If this is the case (there is no throbbing pain from the socket its self, and no bad taste in your mouth) then my advice would be just to take some painkillers (Ibuprofen probably 400-600mg if you can take them) and try and sit it out. There's really nothing you can do to quicken the process, mainly because there's no infection, just a slight bruising of your jaw muscles however the Ibuprofen has a slight Anti-Inflammatory action which could help things along a wee bit.
To be honest, I wouldn't go poking around the surgical site with anything foreign or putting any anaesthetic pastes there if you don't need to - the chemicals in some of these things can dry out the mucosa pretty well and actually hamper healing to a degree so best just to stick to the Hot Salt Mouthwashes.
Cheers, Stu
Bikeless
PostPosted: 09:52 - 07 Apr 2009    Post subject: Reply with quote
pm suitor stu,he is a dentist and will give you some advice,meanwhile i am still putting up with my wisdom tooth as i'm too chicken to get it pulled yet.
Tarmacsurfer
PostPosted: 10:04 - 07 Apr 2009    Post subject: Reply with quote
mattsprattuk wrote:
4 cocodamol
2 paracetamol
3 codeine
wake up in 2 days.
Lightweight.
I'm actually amazed at the quality of replies here, I was expecting someone to have started extolling the virtues of semen as an anti-bacterial agent by now.
The warm salt water idea is probably the best and easiest course to follow, rinse the mouth thoroughly every hour or two and avoid touching/irritating the wound by rubbing pastes/gels around the site.
I'm immortal. Well, so far.
iooi
PostPosted: 10:16 - 07 Apr 2009    Post subject: Reply with quote
Just be carefull of not rinsing too much as it can slow the clotting process. As you are taking away the blood that is setting.
Might also speed up the disolving stiches and cause them to come out before the wound has healed enough.
If the pain is really bad, go back to the dentist. They may give you some nice codine based tablets....
Codine helps the parcentomol to be taken into the system faster and brings much greater levels of pain relief.
Suitor_Stu
PostPosted: 10:18 - 07 Apr 2009    Post subject: Reply with quote
Woh, woh, woh sweet child o' mine! Finals are in 4 weeks, so not quite one yet - don't want to be tempting fate at this stage! Laughing
Stu
Tarmacsurfer
PostPosted: 11:02 - 07 Apr 2009    Post subject: Reply with quote
The clotting process of a mucous/damp membrane is somewhat different to external injuries iirc, also bear in mind there's a steady flow of saliva plus fairly constant motion inside the mouth.
I'm simply passing on the advice I received from my dentist last week to be honest, I had an infection on the gum by a wisdom tooth that had turned into an abcess. Having to wait a few days for an appointment I lanced it myself over the weekend in a fit of desperation and went in to see him on the Tuesday with a chuffing great hole in my mouth. His advice on keeping the area clean - rinse thoroughly with salt water every hour or two, fading in frequency as the wound heals.
Stu; Good luck with the finals Very Happy
Leggy_Girl
PostPosted: 21:43 - 07 Apr 2009    Post subject: Reply with quote
Oh i dunno; you sound like a dentist to me based on your sound advice! Good luck with your finals btw! Very Happy Thumbs Up From what you've said it sounds like bruising. I don't have a funny taste or throbbing pain which is a good thing (i'm guessing!)
Thank you everyone for your genuinely thoughtful and helpful suggestions. I knew you could do serious when required. Wink
*Eats Ibuprofen and puts feet up*
Bikeless
PostPosted: 10:19 - 08 Apr 2009    Post subject: Reply with quote
Yeh,good luck stu with your finals and thanks for past advice, Thumbs Up
The last post was made 17 years, 173 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 106.11 Kb
