| Mattastic |
 Mattastic Trackday Trickster
 Posted: 09:59 - 24 May 2004 Post subject: Minor Oil Leak |
Until this morning I've not ridden the beast that is my GS125 and when i pulled it out of the garage I noticed two little spots of oil, one the size of a pound coin, the other a five pence piece. I had noticed before that when I'd been on a bit of a run there was a layer of oil on the engine casing. I think this is coming from where the "gear changer" (sorry not sure what it's called) goes into the engine. There is a rubber washer sealing it and I'm wondering if that is now worn and needs replacing.
My only worry is that if I take the washer out another one might not slot back in and I may have to dismantle the bleeding thing. Does anyone know if this will be the case? I'll try to post a picture when I get home from work. At the minute it is not a major thing but minor leaks generally turn into full blown ones eventually so i want to get it sorted ASAP. ____________________ Too skint to buy a bike  |
| Robby |
 Robby Dirty Old Man
| Mattastic |
 Posted: 12:47 - 24 May 2004 Post subject: |
Thanks Robby
When I get in I'll check the chain tension, I vaguely remember tightening it a few weeks back, maybe I did it too tight. I hope it is that as I do not fancy taking the engine apart for the sake of a rubber bung! ____________________ Too skint to buy a bike  |
| carvell |
 carvell Scuttler
| Zx6man |
 Zx6man Nova Slayer
| Valentino Mossy |
 Valentino Mossy World Chat Champion
| clemsta |
 clemsta Scooby Slapper
 Posted: 19:16 - 31 May 2004 Post subject: |
My NS125R did that as well, you may need a new gear lever seal which will just be a couple of £, But mine didn't need a new seal it was leaking because i had overfilled the gearbox oil and there was too much pressure, it's easy to change the seal, on most bikes you just take off the gear selector and then prise the seal out with a flat blade screwdriver. Change the oil if you do this. then use a little bit of the new oil and run it around the new seal an insert it into the hole and replace the shifter. fill with oil and then run the bike for 2 mins then check the oil and top up if needed, be carefull not to overfill it or you could wreck the seal.
Hope this has been some use.  |
| Valentino Mossy |
The last post was made 22 years, 156 days ago. Instead of replying here, would creating a new thread be more useful? |
