CG125 dying/dead
kingsknight
PostPosted: 12:56 - 10 Apr 2009    Post subject: CG125 dying/dead Reply with quote
im posting for a friend!he owns a 2006 CG with just 6.5k on the clock!
He broke down on the A3 last night and we have been trying to get him back on the road since 7am today!
He said he was doing 55 last night when the bike felt like it was almost running out of fuel so id started to pull over when the back wheel locked up!
He called the aa out but when they got there the bike started again fine so he started riding back to portsmouth!
The bike started playing up again as he pulled into his mates!
Went to start the bike a few hours later and its is dead!
Cant bump it as the back wheel is locked up!took the head off and the rings and bore look fine!
Oil levels are fine and we only changed the oil a few weeks ago!
When you press the starter you can hear the starter trying to move!
Im thinking it could be the gear box?
Next thing to do is strip down the engine?any ideas?
Much thanks for any help
TS50 (sold) NS125F (sold) NSR125R-K (write off after 2 crashes) CG125 (nicked) XR125L-3 (Sold )-: ) DR125SM '11 (sold yay) XL125V '12 (In love with this bike) XT600E '04 (fun on the dirt)
tomfool101
PostPosted: 15:29 - 10 Apr 2009    Post subject: Reply with quote
It sounds like clutch is stuck.
BRRRRRRRRRRRRRRMMMMMMMMMM!!!i have:
puch moped,
suzuki superbike
nightshaddow
PostPosted: 16:03 - 10 Apr 2009    Post subject: Reply with quote
sounds like you are right though if in nutral is should start anyway my cagiva through its clutch basket springs and seized its gear box, stuck it in nutral and would start straight up.
when you hit the starter is it spining over, start simple then dig deeper maybee post a vid so we can see what you do
kingsknight
PostPosted: 09:50 - 11 Apr 2009    Post subject: Reply with quote
clutch is fine but its acting like the clutch isnt working!
nightshaddow
PostPosted: 15:16 - 11 Apr 2009    Post subject: Reply with quote
can you tell us what you mean ????? how do you know clutch is fine and also how is it acting
kingsknight
PostPosted: 10:05 - 12 Apr 2009    Post subject: Reply with quote
Stripped down the clutch and it looks fine! Plates, springs every looks fine! You pull the leaver and the clutch does pull back fine but the back wheel is still locked!
has to be something in the gear box!
im going to tell him to put it in the shop. not much more i can do with my skill set!
tell you something this has been a bitch of a weekend!
mr jamez
PostPosted: 10:16 - 12 Apr 2009    Post subject: Reply with quote
Can you get the bike in neutral? see if you can turn the crank as you've got the engine cover off.
kingsknight
PostPosted: 12:03 - 12 Apr 2009    Post subject: Reply with quote
Yep feels like its going in and out of gear fine as well!!
its really done my head in!
Blue_SV650S
PostPosted: 13:34 - 12 Apr 2009    Post subject: Reply with quote
I'm confused (easily done!! Laughing) so with the barrel off piston swinging free, does the crank rotate?
If it does, when you turn it, does the rear wheel rotate (even thought it is in neutral)?
kingsknight
PostPosted: 16:39 - 12 Apr 2009    Post subject: Reply with quote
piston and barrel look fine but the con rod does not go up and down at all there is no movement in it at all
Blue_SV650S
PostPosted: 16:42 - 12 Apr 2009    Post subject: Reply with quote
It won't even rock back and forth??? ... Sounds like a big end seizure then ...
kingsknight
PostPosted: 16:55 - 12 Apr 2009    Post subject: Reply with quote
its a CG..... 2006 model...... 6.5 on the clock...... and it had good new grade oil in it!!!
must be the only CG ever for this to happen too if it is Sad he owned it since new as well!
i do think your right tho! nope there is no movement what so ever backwards and forwards! there is more movement side to side then backwards and forwards lol
Blue_SV650S
PostPosted: 17:08 - 12 Apr 2009    Post subject: Reply with quote
Yep, big end gone ... as you say very rare for a CG (with oil in it) to have a big end failure. Bad luck to your mate!! Sad
You have nothing to lose going in there and seeing if you can repair it ... a new big end crank pin, big end shells and a con-rod shouldn't be stupidly expensive. You will need an engineer to split and re-make/align the crank thought ... if it was a high millage engine, I'd say chuck it and get a 2nd hand one, but on one so young, its gotta be worth doing the sums.
You also need to see if it was just a freak thing or if it was lack of lubrication. Check the oil pump and the oil strainer/filter bit ....
BTW, the later CGs were NOT made in Japan IIRC, they were made elsewhere under license ...
kingsknight
PostPosted: 08:26 - 13 Apr 2009    Post subject: Reply with quote
putting the bike in the shop on wednesday! ill keep you all updated on what happens when we get the call. He knows the guy who owns the shop do we are hoping its not going to cost to much!
kingsknight
PostPosted: 10:41 - 15 Apr 2009    Post subject: Reply with quote
the engine is dead!got a call from my mate and the shop called and said that it would cost to much to fix the damage to the engine!
The shop said that it looked like it ran out of oil but there is no way that happened as i was there when he done the last oil change!
We found an engine for £200 plus shipping so we are going to put that in it!
He is the only bloke i know who could kill a 2006 Cg! He did rag it about non stop everywhere he went!also i found out he played around with the carb settings and put a different air flitter on there!
Cant believe i didnt notice the air flitter when i helped strip down the head the other day lol
The last post was made 16 years, 256 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.29 - MySQL Queries: 13 - Page Size: 88.71 Kb
