Sump Funked!?
Tom1528 This post is not being displayed because the poster is banned. Unhide this post / all posts.
PostPosted: 22:51 - 10 Apr 2009    Post subject: Reply with quote
Yes a helicoil would work just fine. I have done a couple. If not, then tapping a size larger and using a larger plug would also work well.
Ichy
PostPosted: 23:05 - 10 Apr 2009    Post subject: Reply with quote
I generally find that its not the plug that gets damaged, the sump is softer. As a temporary fix you could try a rubber washer to help give a better seal.
Might be worth running a tap through the thread before you fit the new plug.
MattEMulsion
PostPosted: 15:29 - 11 Apr 2009    Post subject: Reply with quote
Try a bit of PTFE tape around the threads on the sump plug, but a visual inspection should tell you whether either of the threads are knackered on the sump or the plug. Whatever you do though, don't bodge it, as a failure could easily lead to either a knackered engine or a big accident due to the oil getting under your rear tyre.
Yamaha YZF-R6
Finglonga
PostPosted: 15:58 - 11 Apr 2009    Post subject: Reply with quote
Then buy a Torque wrench. Wink
Andy Sez....
F.Y.Y.F.F.
The last post was made 17 years, 131 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 44.08 Kb
