| The Artist |
 The Artist Super Spammer
| Ichy |
 Ichy World Chat Champion
 Posted: 11:46 - 11 Apr 2009 Post subject: |
Might just be down to the fuel evaporating due to heat, you need to kick it a few times to get some back in there Maybe running a bit rich? If that is the only problem then I wouldn't worry about it too much.
RANDOM DRIVEL: Petrol supplied in the winter can have a slightly higher volatility rating (called "Reed vapour pressure") since its unlikely to get hot enough to boil away. This makes it easier to start from cold but does make the bike more susceptible to warm start problems. In the summer the volatility rating is lower so the problem goes away. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| The Artist |
| Ichy |
 Posted: 12:17 - 11 Apr 2009 Post subject: |
Sorry for all the questions. Are you talking about the GS? Do you need the choke when you start from cold? Have you check the valve gaps? Is the choke working correctly? I've assumed you've already checked the plug colour and its all looking good?
You could try turning the mixture screw back a quarter turn and see if it makes a difference? Easy enough to put right again after. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| Gawain |
 Gawain Nitrous Nuisance
| The Artist |
 Posted: 13:08 - 11 Apr 2009 Post subject: |
I haven't checked the valves. Everything else has been checked. Plug is new (last week) and is perfect brown colour.
Oil and oil filter were also changed.
How do I check the valves? I have taken the rocker covers off and I see a small flathead screw.
Can someone run me through the procedure.
Cheers
EDIT: I have a 30 mile trip at 3pm so is it possible to do it before then? I don't have any feeler gauges as I found mine and its rusty so inaccurate. |
| spitfire123 |
 spitfire123 Could Be A Chat Bot
| The Artist |
| Itchy |
 Itchy Super Spammer
 Posted: 13:27 - 11 Apr 2009 Post subject: |
erm according to Peter , kicker only bikes are a pig to start when hot anyway , as I was considering buying a TT600R kicker only he said well you really want electric and kick start as kickers can be a pig to start when hot.
He went on further to add that he said you have to wait for them too cool down before attempting to kick them to life again. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| spitfire123 |
 Posted: 13:31 - 11 Apr 2009 Post subject: Re: Harder to start when hot |
[/quote]
Surely they expand when warm?[/quote]
 ____________________ You won't be able to eat my dust......As it'll settle before you get there. |
| The Artist |
| Ichy |
 Posted: 14:03 - 11 Apr 2009 Post subject: |
Don't take it a gospel, I'm working from a very old memory but I think the exhaust should be 0.13mm and the inlet about 0.08mm, slightly bigger is better than being smaller.
Your going to need some feelers or some random bits of plastic and a micrometer. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| Frost |
 Frost World Chat Champion
The last post was made 17 years, 129 days ago. Instead of replying here, would creating a new thread be more useful? |
