Building a fence... and converting garden to parking spac
 Topic moved: from Random Banter to Dear Auntie BCF... by G (12 Apr 2009 - 13:19)
Sparks!
Sir Tart-a-lot
PostPosted: 18:20 - 11 Apr 2009    Post subject: Building a fence... and converting garden to parking spac Reply with quote
Question 1
Garden fence... its fucked, need a new one! Is it as simple as postcrete in wooden posts then screw the fence to the posts and trellis the top? obviously thats a very simplified description, I'm not a biulder but I am an electrician so have general "construction" skills. Just need to know if there's anything I need to consider / do extra to posts + panels + decorative tops
Question 2
Front garden, currently walled off. have numerous parking issues so I'm considering taking out the side wall digging out two wheel sized trenches, lining and gravelling them so we can park a car on the front garden.... simple as that?? it's a grass lawn area, the wall is pretty much a stand alone so no real hassle removing it.. just some bushes to remove and its clear access from the drive into the garden...
only thing is you'd have to reverse into the garden from the road, there is a dropped curb but youd prob have to go slightly up the kerb to make the 90* turn. tbh i have to go up on the grass to get my truck in the drive anyway so don't see this as a big issue?
Any tips/advice much appriceated, like special tools needed etc?
Tonka
PostPosted: 18:30 - 11 Apr 2009    Post subject: Reply with quote
Well, believe me if I can put a fence up, by myself I might add, you'll have no problem Laughing I only had to put in 2 6ft panels, 3 posts but it was a right palaver digging the holes for the posts as one was next to a hedge with big roots! Used the quick set cement stuff which is a bit pricier than normal cement, but still cheaper than those fancy metal post holders (metpost?) I was doing it on the cheap, hence doing it by myself! Only mistake I made was I got too eager and fixed the panels on before the posts had set properly, so the middle one moved and I've yet to re-do it!
No idea about the garden, but I think if you've got a dropped kerb you can usually get away with cars on the front wherever you like.
MattEMulsion
PostPosted: 18:53 - 11 Apr 2009    Post subject: Reply with quote
How long do you want the fence to last? Wooden post straight into the ground will rot sooner or later. For a long lasting job you ought to look towards concrete posts.
Yamaha YZF-R6
garth
PostPosted: 19:11 - 11 Apr 2009    Post subject: Reply with quote
If you wanna knock down the wall I don't mind driving your truck into it for you. Thumbs Up
Skudd
PostPosted: 19:17 - 11 Apr 2009    Post subject: Reply with quote
Use post spikes and put the wooden posts into them. get them from B&Q for about £5 each.
Sparks!
Sir Tart-a-lot
PostPosted: 19:18 - 11 Apr 2009    Post subject: Reply with quote
No need mate, the wall could be blown down quite easily let alone knocked.... Laughing I plan to just push it over then pick the blocks up haha. Might build something out of the blocks maybe haha.
Matt.. someone did mention concrete posts but tbh I don't think it's really neccessary... its my mums house where I'm doing the work and she's on a slight budget, so will go with wooden posts.. would I be better off with some form of fence bracket/post in the ground rather than postcrete - ing
Flip
PostPosted: 19:21 - 11 Apr 2009    Post subject: Reply with quote
Treated wooden posts in concrete (or you can f*ck the concrete off and just dig holes (don't need to be huge, just twice the size of the post maybe) and pack the posts in by tamping the smashed bricks from the wall down around it, just as strong as concrete, then cover the top with soil). Tamp, add rubble, tamp etc. (Don't forget to check the levels as you go).
https://i2.photobucket.com/albums/y37/flip_/posthole.jpg
Treated wood is good for 20 years. Nail the rails to the posts. To make it vandal proof put 2 nails in a 'V' shape ( \ / ) rather than one nail staight in to it ( | ). That way you can't just pull the fence down so easy
https://i2.photobucket.com/albums/y37/flip_/Nails.jpg
Look at how ace my pics are!!
Sparks!
Sir Tart-a-lot
PostPosted: 19:24 - 11 Apr 2009    Post subject: Reply with quote
Do I still need to concrete them in or do they just go in the ground then put mud back around them? Quite happy to use spikes if it'll mean a better longer lasting job
MattEMulsion
PostPosted: 19:33 - 11 Apr 2009    Post subject: Reply with quote
If you are doing it on a budget then just plonk the wooden posts straight into the ground. I would stretch to concrete if nothing else though especially if it is a big tall fence.
Yamaha YZF-R6
Flip
PostPosted: 19:38 - 11 Apr 2009    Post subject: Reply with quote
Nah, just smash the wall up into fistsize (prob smaller) pieces and tamp them down, more bricks/rubble, tamp it down. No cost at all.
That's how most farmers fence posts are held up. (It used to be my job).
Clanger
Stirrer
PostPosted: 20:31 - 11 Apr 2009    Post subject: Reply with quote
Use a bit of your old fence across the edge of the kerb, angle it slightly if you have the tools - this is cheaper than getting the council to give you a dropped curb.
Dischord
PostPosted: 21:17 - 11 Apr 2009    Post subject: Reply with quote
Jesus christ, how complicated can you lot make things Very Happy
2012 KTM EXC 250
pablouk
PostPosted: 22:42 - 11 Apr 2009    Post subject: Reply with quote
DO NOT use metaposts. They are shite, and your fence absolutely WILL fall down after a year or so. You just hammer them in, they are for numptys who can't be arsed to do a proper job. After a couple of puffs of wind, they loosen.
Keeping The Nation Pissed
Do not anticipate trouble or worry about what may never happen. Keep in the sunlight. ~Benjamin Franklin
Skudd
PostPosted: 00:37 - 12 Apr 2009    Post subject: Reply with quote
Mine lasted over ten years in my last house and two years so far at this one. Quick and easy. it depends on yor soil/ground. Obviously you use the right method for the area they are to be placed.
iooi
PostPosted: 10:02 - 12 Apr 2009    Post subject: Re: Building a fence... and converting garden to parking spa Reply with quote
Sparks! wrote:
Question 2
Front garden, currently walled off. have numerous parking issues so I'm considering taking out the side wall digging out two wheel sized trenches, lining and gravelling them so we can park a car on the front garden.... simple as that???
You will need to check the house deeds or with the local council as you may not be able to park infront of your house...
We are not supposed to park in front of our building line, due to some regulations....
Road is fine, just not on your garden.
Sparks!
Sir Tart-a-lot
PostPosted: 11:43 - 12 Apr 2009    Post subject: Reply with quote
We've just checked the deeds, no mention of the front garden so we're assuming its okay.. mums going to check with someone next week though (she's an estate agent so has people to ask etc..)
Tomorow I am doing the smaller of the two fences I'm building.. this one is on a concrete area.. I presume with concrete areas I DONT need gravel boards? Going for wooden posts bolted to the floor and to a 1ft raised concrete area so they will be pretty damn secure. 5ft panels.
By the way.. normal fence panels nail inbetween each post....is it possible to secure these to the flat edge of the posts? so all the posts are on the back of the fence and the panels run in front of them butting up to each other? if that makes any sense at all?
Like this:
https://www.thelogfactory.com.au/prodimages/Utility_fence.jpg
This is pretty much exactly what I intend for the longer side of the garden..
https://www.chiswickfencing.com/Images/CNV00005_640-512.jpg
So obviously the left side needs to match this.. this wall/fence seperates our drive from the garden... there is an approx 1ft drop down from the drive into the garden.
IF I build with the posts on the garden level then I'll need to cut the door down at the bottom to allow for a step? whereas if I can put the posts on the garden level but then fit the panels on the drive side so the panels are 1ft higher than the base of the posts the door will open at drive level which will allow for the step....
The thing with this is I need to make this fence match the other fence, so can this be done with panels?
does that make any sense at all cos im not sure it does?? Laughing
I'm gonna go rip the wall down now, I'll get pictures it might make more sense!! Laughing
Tarmacsurfer
PostPosted: 12:04 - 12 Apr 2009    Post subject: Reply with quote
I really like them, mainly as people build with the things then a year or two later get pissed off with them repeatedly blowing down and pay people like myself to build a fence.
Sparks, wood framing is fine for dry and fairly compacted ground but if it's damp/loose soil then light-crete posts cemented in about 2' down and a gravel baseboard with wooden top panel is the way to actually make something that'll stand for a while and look tidy. Not the cheapest way of doing things though, plus it's a bit of work getting the height and lining up right. Even on a wooden bolt together job a big spirit level is your friend Thumbs Up
If there are no obvious covenants on your deed then the parking should be fine, you only usually find stuff like that on ex-council properties in my experience, that's fairly limited experience though Razz
I'm immortal. Well, so far.
PostPosted: 14:24 - 12 Apr 2009    Post subject: Reply with quote
20 years and still standing. Methinks you didn't hammer the posts in far enough.
Sparks!
Sir Tart-a-lot
PostPosted: 16:34 - 12 Apr 2009    Post subject: Reply with quote
Why did this get moved to Dear auntie bcf? it's more random banter than is dear aunty bcf Rolling Eyes but still..
I've now removed the old wall completely and the old trellis that was in place... also started pressure wash cleaning the concrete drive, amazing difference already!
we've confirmed going ahead with the front garden modifications so I'm now building the fence in place of the old wall which means I'm building directly onto concrete. makes things a bit easier!
panrider_uk
PostPosted: 19:23 - 12 Apr 2009    Post subject: Reply with quote
Because Dear Auntie BCF..." is "The place to ask the forum for advice on life, the universe, and everything."
Mark
pablouk
PostPosted: 23:17 - 12 Apr 2009    Post subject: Reply with quote
Battered those bad boys all the way down!! Maybe Skudd and you live in very light wind areas? The major design flaw is that as soon as the wind blows a bit, it causes the metapost to flex just a fraction, opening the hole also a fraction. Next gust of wind opens it a fraction more etc. After a while, the once tight metaposts are now flopping about in giant holes!!!
The last post was made 17 years, 156 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.96 - MySQL Queries: 16 - Page Size: 117.83 Kb
