Oil Level Sensor
Bazz150
PostPosted: 08:38 - 12 Apr 2009    Post subject: Oil Level Sensor Reply with quote
Can anyone advise me
why the oil level sensor light comes on after about a hours ride.I ride a FZS 600 2002, the oil level is correct.
The manual states the light may come on under certain conditions ie rapid acceleration or going up hill.
Once it comes on it stays on untill i let it stand for a few hours ???.
Any thoughts thanks.
Its an oil level sensor and the oil is on the top level mark.
iooi
PostPosted: 09:49 - 12 Apr 2009    Post subject: Reply with quote
Is it a level or pressure sensor ???
When you are checking the level are you sure the bike level ? Try turning it round and see if its the same.
It is possible that something is blocking andstopping the flow of oil back to the sump, so after a while there is next to no oil in the sump. Or that the wires to the switch are shorting out...
I would change the oil and the filter and see if the same happens again.
mr jamez
PostPosted: 12:01 - 12 Apr 2009    Post subject: Reply with quote
I had this on my S4 (oil pressure switch)
One of the previous owners sent it down the road in its right hand side and the switch was damaged, now and again the ring connector would wobble and come into contact with the engine or frame and the light would come on.
So hopefully its just a fault with the switch.
PostPosted: 12:18 - 12 Apr 2009    Post subject: Reply with quote
The oil level sensors that Yamaha use do malfunction occasionally. Could try taking it out and cleaning it, but might be easier to just replace it.
Blue_SV650S
PostPosted: 14:48 - 12 Apr 2009    Post subject: Re: Oil Level Sensor Reply with quote
When you say the oil level is correct, do you mean its on the upper mark or just between the upper and lower marks?
The last post was made 17 years, 124 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.62 - MySQL Queries: 13 - Page Size: 44.58 Kb
