Suzuki GS500E: Help!
Chri
PostPosted: 19:38 - 14 Apr 2009    Post subject: Suzuki GS500E: Help! Reply with quote
Hi all, i've just been given a Suzuki GS500E 1999, in really good condition apart from one thing, the front Engine Mount has snapped off and is gone! & i've tried everywhere to get it cast welded back up but so far it will cost me more than the bikes worth Crying or Very sad
The Rest of the Engine is Mint so it would be a real shame to have to swap it, any advice on this would be very very much appreiciated Very Happy
Fisty
PostPosted: 20:31 - 14 Apr 2009    Post subject: Reply with quote
Not much you can do with that im afraid, look for a second hand engine/ casing.
Fatter and faster than Fret
Blue_SV650S
PostPosted: 20:40 - 14 Apr 2009    Post subject: Reply with quote
How many other mounting points are there and where are they?
To be honest - its not ideal obviously - but I can't see the engine going far, unless its vibrating like a b-steward or its only mounted in one other point, I'd be tempted to leave it and just ride the thing!! Wink
Assuming there is no physical movement there, you'll be amazed at what a good areldite job will do for you!! Thumbs Up
You can get 'chemical metal' which is the same idea but a bit more metal orientated ... its not going to hold much load, but will give some support to aid the other mounts to do their job!! Thumbs Up
Chri
PostPosted: 21:31 - 14 Apr 2009    Post subject: Reply with quote
I've tried loads of breakers, they either don't have a casing or there not willing to strip one down Sad
Chri
PostPosted: 21:35 - 14 Apr 2009    Post subject: Reply with quote
Not sure how many other mounts there are but i will look, the engine itself is fixed into place very solid, did'nt think of chemical metal (Nice1) but my main worry is can i dress it up good enough to pass the M.O.T
virus
PostPosted: 22:16 - 14 Apr 2009    Post subject: Reply with quote
or can you cut it out with a grinder and paint it over well enough to look like there was never one there in the first place?
front engine mount bolt is a common problem on gs500es though, I wouldnt worry about it too much, just find a good MOT tester.
John
own: 81 xs1100g...
Chri
PostPosted: 22:31 - 14 Apr 2009    Post subject: Reply with quote
John
That could just work! Smile
Thx
PostPosted: 01:59 - 15 Apr 2009    Post subject: Reply with quote
I have the majority of a bike with a knackered engine you can have for 50 notes. It has a solid frame and V5. All you have to do is pick it up from Hornchurch essex.
Blue_SV650S
PostPosted: 10:41 - 15 Apr 2009    Post subject: Reply with quote
Thx
DON't cut it off FFS ... what little support that is giving at the mo has to be better than NO support ... you said yourself it wasn't going anywhere!! ....
Some chemical metal to 'build it up' and a bit of oil and mud thrown at it so as not to draw attention has to be the way forward ..
Ichy
PostPosted: 10:51 - 15 Apr 2009    Post subject: Reply with quote
I'm with him ^^^^
Leave whats there, build it up whith jb weld or chemical metal and then maybe attach a thin aluminium plate, bent around the bolt, to the remaining casing to give it a finished look.
Chri
PostPosted: 11:17 - 15 Apr 2009    Post subject: Reply with quote
Blue_SV650S wrote:
Thx
Very Happy After reading your last post i've looked into using chemical metal and i must say "brillient idea" Thumbs Up Thumbs Up Thumbs Up , might have a seized engine coming my way though Very Happy Thanks to Chris-Red.
Big Thanks all who have posted, really appreiciate the help Karma
Blue_SV650S
PostPosted: 11:27 - 15 Apr 2009    Post subject: Reply with quote
As itchy mentioned JB weld is the same idea .. and you can get that from Halfords, so you don't need to find a place that sells chemical metal! Thumbs Up
The last post was made 16 years, 253 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 77.57 Kb
