NSR strange sound
monkeyman
PostPosted: 00:15 - 25 May 2004    Post subject: NSR strange sound Reply with quote
Im not really sure but i think my NSR has developed a new sound i have never really thought about it but recently its being getting on my tits.
When its just ticking over there is a very noticeable thudding sound much louder, i cant really hear it when the power is on.
I was wondering if the the big end bearing may have gone. I was once told it sounded like someone taking a lump hammer to your engine case, although i don't think it really sounds like that.
The tick over isn't that great either, sounds like its going 2 stall any second.
Any ideas.
Im not the best, but im in the top one
RM 250, Husky TE610, K1 GSXR 750
craigT19
Jolly Green Giant
PostPosted: 08:29 - 25 May 2004    Post subject: Reply with quote
my nsr did that when it was cold....or needed a service.
regards Thumbs Up
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
monkeyman
PostPosted: 13:02 - 25 May 2004    Post subject: Reply with quote
Are you sure because, it wasnt really cold yesterday and i had just been riding it, And its had all the oil ect changed recently.
Also it starting leaking petrol from a pipe at the bottom, i belive it was syfening it from the tank as a lot was comming out untill i moved the bike and its stopped.
Odd?
jimbo
PostPosted: 21:23 - 25 May 2004    Post subject: Reply with quote
A bit of petrol can go into the overflow pipe when you're filling it up, and if the hose has a bend or crap in it the fuel will dribble out some time later. If it only happens once or twice don't worry about it.
Fuel overflow can also be due to the carb float sticking down, and would possibly cause your idle problem as it messes up the fuel/air mixture. Normally this is a continuous problem though, with fuel piddling out of the carb overflow. Moving the bike can shake it free and let the needle seat again. Fairly rare kind of thing.
As for noises, they're very hard to describe. If the piston is worn and slapping you hear it as a fast tapping noise when the engine is idling.
If the big end is gone it's supposed to sound pretty loud like a knock and gets worse very quickly.
If a main bearing goes it's more of a rumble, and you'll feel the vibrations through the frame. The engine can run for quite a while like that before the bearing collapses and things get expensive.
On the bright side, every NSR i've ever heard has some grumble from the engine, the older they get the louder it gets
nsr125sp
PostPosted: 22:18 - 26 May 2004    Post subject: re Reply with quote
hello, this happend to my nsr! sounded horrid, i left it for a while until it siezed on me as the oil wasn't flowing around, the problem was the primary gear nut had come off, which moved the gear which drives the oil pump, would be a idea if you check it,
Cya Ollie
Nsr 125, Vfr 400
https://www.bikepics.com/members/nsr125sp/
monkeyman
PostPosted: 09:29 - 28 May 2004    Post subject: Reply with quote
where abouts is this, keith?
How much is it likly 2 cost if i take it 2 a garage.
The last post was made 21 years, 296 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.26 - MySQL Queries: 13 - Page Size: 48.17 Kb
