Carb icing - in this warm weather?
apple tango
PostPosted: 20:54 - 20 Apr 2009    Post subject: Carb icing - in this warm weather? Reply with quote
When idling, even when the engine is up to temperature, it's on the verge of stalling. It idles at about 400 when usually its over 1000.
At low speed it chugs along with no acceleration but picks up over 4000/5000 rpm.
It was doing this in the winter on cold foggy mornings, so i don't understand why its doing it again with the current warm temperatures.
I've checked the choke at the carb end and it seems fine.
Any ideas?
CBR125 -> Bandit GSF600 '99 -> SV650 02
Thom
PostPosted: 21:03 - 20 Apr 2009    Post subject: Reply with quote
I'd be saying clean your carbs, its certainly not carb icing if the problem goes away when your main jet kicks in and the revs increase Thumbs Up
I'd say its a blocked pilot jet tbh or atleast a grotty carb.
Ichy
PostPosted: 22:32 - 20 Apr 2009    Post subject: Reply with quote
Clean the carb. It may be flooding slightly at low revs. Check the float and needle valve.
Try changing the plugs if you have some spare. It might be a dodgy plug that is picking up at higher revs. Use the idle speed adjuster to bump the revs up a bit, to stop the bike stalling. Start the bike and, while wearing rubber gloves, remove each plug cap, one at a time. Revs should drop, if not then you've found a dodgy plug.
Phoenix
Twisted Firestarter
PostPosted: 04:42 - 21 Apr 2009    Post subject: Reply with quote
It's not carb icing and probably wasn't during your foggy mornings either, that usually appears when you slow down after a stint at speed, the fuel lines/carbs suddenly start freezing up and you effectively run out of fuel, often conks out and has to be left until it melts.
As others say, clean the carbs, check your idle adjustment and balance them.
apple tango
PostPosted: 17:14 - 23 Apr 2009    Post subject: Reply with quote
Thanks for the tips.
Bearing in mind i'm complete novice when it comes to repairing bikes, is cleaning the carbs a tricky job?
The most advance thing i've done is an oil and filter change Smile
The last post was made 17 years, 52 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.82 - MySQL Queries: 13 - Page Size: 44.79 Kb
