Fogging up Visor!
EUMP
PostPosted: 20:42 - 21 Apr 2009    Post subject: Fogging up Visor! Reply with quote
Arghh!
First off my helmet is the Shark S500 Texas Hold'Em edition, nice helmet Smile Visors anti-fog, but fogs up! Added anti-fog foam - still fogs up! Breath deflector & anti-fog foam = 2minutes then fogggy'
Im running out of ideas and been riding a while with the visor up, also had the same problem on my Nitro helmet years back
tutton
PostPosted: 20:45 - 21 Apr 2009    Post subject: Reply with quote
Not got any vents on the lid, my arai has a vent infront of the mouth hole which opens up on 3 different clicks for quick demisting.
cammy mack
PostPosted: 20:46 - 21 Apr 2009    Post subject: Reply with quote
have you tried getting a pinlock visor for it?
EUMP
I have two side vents and a front mouth vent to on my Shark, still fog'
B10Hazard
PostPosted: 21:02 - 21 Apr 2009    Post subject: Reply with quote
Foggy mask ! * simples
https://www.respro.com/products/racing/off-road-racing/foggy_mask/
They Velcro into your lid and are awesome.
I have one
No longer any socks
The Artist
PostPosted: 21:04 - 21 Apr 2009    Post subject: Reply with quote
I can't believe your visor fogs up in this weather.
Should be a vent. Otherwise use a foggy mask or pinlock.
Faraz
PostPosted: 21:28 - 21 Apr 2009    Post subject: Reply with quote
+1 for the foggy mask.
Works brilliantly. Feels weird riding without one now.
'56 Yamaha MT-01
'05 Nissan 350z Roadster GT
3 words dude.. Fvck. Yes.
The Tot
PostPosted: 21:43 - 21 Apr 2009    Post subject: Reply with quote
Okay I use:
Arrow Respro Foggy mask
Arrow Fog City Clear on my tinted visor
Arrow Pinlock Clear on my clear visor
so effectively, i've got 3 different products serving the same purpose. I prefer the fog city and respro combination since the film thickness of the fog city is a lot thinner than the pinlock. You don't seem to have the thick sealant restricting your peripheral vision as well as the pinlock posts obscuring your view.
Respro keeps your face, mouth and nose warm in winter when used in conjunction with a balaclava too.
Lid is an Arai Corsair btw which does have a very effective ventilation system though not as good as a shoei X11.
With the respro, keep your mouth/chin vent open at all times as well as rear vent open to aid the demisting.
Never argue with autism
Charlie
PostPosted: 23:21 - 21 Apr 2009    Post subject: Reply with quote
Pin-lock, I couldn't use a helmet without one any more. In fact I forget it happens until I either see a fogged up visor (someone else's) or there is a thread on it.
Flip
PostPosted: 23:27 - 21 Apr 2009    Post subject: Reply with quote
Took my pinlock visor off. Best thing I've done for a while. Thumbs Up
Charlie
PostPosted: 23:46 - 21 Apr 2009    Post subject: Reply with quote
How come Flip?
ZRX61
Victor Meldrew
PostPosted: 00:00 - 22 Apr 2009    Post subject: Reply with quote
Apparently no one in this thread has ever heard of fairly liquid... Rolling Eyes
The Tot
PostPosted: 00:06 - 22 Apr 2009    Post subject: Reply with quote
Yeah... and THAT didn't work. In wet and cold winter morning, all it did was blur my vision. Problem was exacerbated by the fact that i wore glasses the instead of contacts. I hated havign to reapply fairy liquid and when you're out of luck, you end up using some hand lotion that has microbeads in them! Twisted Evil Lesson learnt.
Flip, did you not adjust your pinlock pins to get a better fit, or were you generally just pissed off about the fact that you had a thick rim around the periphery of the visor?
pa_broon74
PostPosted: 00:13 - 22 Apr 2009    Post subject: Reply with quote
Try G-wax.
Use sparingly and polish off properly.
(I know, its a wax for walking boots but it does work. Plus, it lasts.) I did try it with some neutral wax polish but it smelled of proper shoe polish and almost had me overcome with the fumes.
So, G-wax... Also works well on the outside for stopping beading...
Didn't catch anything.
ZRX61
Victor Meldrew
PostPosted: 00:16 - 22 Apr 2009    Post subject: Reply with quote
Worked for me thru 8 Winters of despatch riding in all weathers... Rolling Eyes
Flip
PostPosted: 03:44 - 22 Apr 2009    Post subject: Reply with quote
I adjusted them when I cleaned the insert but always felt there was a distortion there. Maybe because I wear glasses and 3 layers lens/visor was too much for it to work properly? Think my vision is a bit funny anyway tbh. Laughing
iooi
PostPosted: 05:58 - 22 Apr 2009    Post subject: Reply with quote
Do you wear a something round your neck, and up under the helmet, because they can stop the warm air being vented out.
All this fogging up, is it while you are riding or when you are stood still ?
B10Hazard
PostPosted: 22:57 - 22 Apr 2009    Post subject: Reply with quote
Not true, i began to write about that little trick but i must have moved my mouse or something and started to write in a random place. Then deleted it all by accident, so i couldnt be arsed writing it all again so i went for the easy foggy mask option, but in the time i have explained what i did in this reply i could have wrote it again anyway. Hmmmm any way ill shut up now.
Omg i wrote that so quick my fingers are on fire .
Cool
No longer any socks
Charlie
PostPosted: 23:38 - 22 Apr 2009    Post subject: Reply with quote
I am sure ctrl-z would have recovered it eventually?
krebsy
PostPosted: 12:14 - 23 Apr 2009    Post subject: Reply with quote
I've a pinlock in my Shoei XR 1000 but i think I need a bigger insert as I'm often looking through the top beading.. Sad I'll see if I can adjust it for a better fit though. It might be slightly off as I'm getting a bit of misting at slow speeds.
I've also got a tinted insert (Should use now it's summer) but will buy a spare visor to fit it to rather than faff about swapping inserts over.
Best one I had was a stick-in Fog city Photo-reactive insert. Great at keeping the fog at bay and got quite dark in the blazing sunlight. Thumbs Up Cost about £30 though at the time but well worth it....
K.
1280 x 1024.
tintin
PostPosted: 09:57 - 24 Apr 2009    Post subject: Reply with quote
I've used this stuff and it's pretty good, not if you are stationary for more than 30 secs on a cold day, but you need to reapply it every week or two.
A Pinlock really works best though, I just find them a bit distracting.
The older I get the better I was
EUMP
PostPosted: 13:18 - 25 Apr 2009    Post subject: Reply with quote
Riding and stood still, it's a really annoying thing to shift and its the time of the year for bugs in your eyes
EUMP
PostPosted: 13:19 - 25 Apr 2009    Post subject: Reply with quote
And for the foggy mask, i've got pretty much the same thing by oxford Very Happy
Louise
PostPosted: 15:13 - 25 Apr 2009    Post subject: Reply with quote
I do have a foggy but sometimes as I put the Arai on I tend to suffocate myself when its not fitted correctly Laughing
I have a neck warmer which sits over my nose - helps a lot as my iridium dose not have a pinlock yet Thumbs Up
The last post was made 17 years, 149 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 120.88 Kb
