Daytona 675 running really high temp....
AngelGrinder
PostPosted: 21:14 - 21 Apr 2009    Post subject: Daytona 675 running really high temp.... Reply with quote
As per the title, had a bit of a crash the other week, just got bike back on the road and it's getting very hot!
I've taken the fairings off, water levels are fine. I've tried sqeezing the pipes to the radiator, the bottom one feels like it has very little water in, the top one feels completely empty.
When I start the bike, the left hand side of the rad (where the pipes are) get's hot, the right hand side takes alot longer to heat up, and the top of it does not get hot atall.
The fan is working fine.
After the bike has got really hot, I can still put my finger in the watertank and it's not hot, and there is no pressure in the radiator cap....
Any ideas? Shall I drain and refill everything?
Or is the waterpump likely to have had it?
B10Hazard
PostPosted: 21:26 - 21 Apr 2009    Post subject: Reply with quote
Well sounds like it. I mean i cant see anything else that could cause this.
Although do drain and refill everything !
Is it a big/expensive job a new water pump ?
No longer any socks
AngelGrinder
PostPosted: 21:28 - 21 Apr 2009    Post subject: Reply with quote
Trying to find out...it looks like it!
PostPosted: 21:40 - 21 Apr 2009    Post subject: Reply with quote
Check if there is a bleed screw somewhere in the system. Could be that some coolant has leaked out and left an air lock in the system.
AngelGrinder
PostPosted: 21:51 - 21 Apr 2009    Post subject: Reply with quote
Can I pour tap water into the top of the radiator? Then 'burp' all the pipes?
A while ago my zx9 was overheating doing the mile and a half trip to my old work. It's now fine commuting for twenty minutes through a town centre every day, after I drained and refreshed water in it... was just thinking today that it probably was an airlock.
PostPosted: 21:53 - 21 Apr 2009    Post subject: Reply with quote
Can try (although try using a water / antifreeze mix).
AngelGrinder
PostPosted: 21:57 - 21 Apr 2009    Post subject: Reply with quote
I have no antifreeze, I'll drain it all out and put some new water and anti-freeze tomorrow....just want it to run ok for half a day..
Wooly R6
PostPosted: 13:59 - 22 Apr 2009    Post subject: Reply with quote
I have heard of faulty rad caps causing high temps too. I would replace the coolant first - i reckon its just an airlock.
R6 has been sold - 2004 Honda VFR VTEC now sold too - no bike at the moment
The last post was made 17 years, 79 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 3 - MySQL Queries: 13 - Page Size: 63.17 Kb
