Axel Problem
untitled_warrior
PostPosted: 23:59 - 21 Apr 2009    Post subject: Axel Problem Reply with quote
Hello,
I removed my rear wheel from my dt125r today and on inspection of the axel and what i assume is the spacers, i noticed this:
bent "spacer" in question:
https://www.e-imagesite.com/Files/DSC_01249078897.gif
The axel in full:
https://www.e-imagesite.com/Files/DSC_01232655907.gif
the "spacer" has been bent, on the part which goes into the wheel (covering/sealing the bearings i'm assuming), does this pose any sort of problem for my bike or does it need replaced ?
Thanks for all the help
david
BanditsHigh
Worse than a woman
PostPosted: 08:02 - 22 Apr 2009    Post subject: Reply with quote
If it's the bit I think it is then no ... it's just to prevent the majority of crap getting between the spindle and the wheel.
If it's the same as other bikes you'll find it's a stamped piece of metal which is pushed onto the spacer ... you should be able to knock it off and then straighten it up before putting it back on.
All the best ... Barry
The last post was made 17 years, 160 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 31.64 Kb
