Solution for a puncture?
neil.
PostPosted: 08:07 - 22 Apr 2009    Post subject: Solution for a puncture? Reply with quote
Damnit, went to the garage this morning and the back was flat. Then I see a small nail sticking out of a groove in the tread. Sad Now I'm stranded as it'll cost me in the region of £20 to get to work and back by train which I'm not doing. So, gotta get this thing fixed but I'm wondering what the best way is? Replace the tube, patch it with a bicycle kit or try out one of those products that 'gloops' about inside the tube and seals the puncture for a quick fix? Bearing in mind I need to get to work at some point today!
Ta!
Grr! Evil or Very Mad
thewildblue
PostPosted: 08:11 - 22 Apr 2009    Post subject: Reply with quote
Take the wheel out and go down to a car repair place, get them to put a "bung" in, like a proper repair.
I dont trust the goo stuff.
neil.
PostPosted: 08:42 - 22 Apr 2009    Post subject: Reply with quote
It's a tubed tyre I don't think it can be plugged as such. I have the back wheel off now, but not the tools/expertiese to get the tyre and tube off/on again by myself. I found somewhere which is a small train ride away that can sort it though. Cheers for the suggestion. First puncture in 13'500 miles, much better than my old bicycle anyway!Thumbs Up
neil.
PostPosted: 09:20 - 22 Apr 2009    Post subject: Reply with quote
Hm my better half just suggested that I keep a spare wheel with tyre fitted to it so I can drop it in if this were to happen again, because I need my bike for work... anyone else do that, or is it a bit silly?
alun111
PostPosted: 13:07 - 22 Apr 2009    Post subject: Reply with quote
It seems like a good idea.. but you have to take into consideration the cost of a modern ybr wheel. If it was an old CG I'd say do it as a wheel with a tyre can be picked up for about £20, but I'm just not sure it will be cost effective on the ybr.
neil.
PostPosted: 13:15 - 22 Apr 2009    Post subject: Reply with quote
Indeed, well I was only 4 hours late for work! Had to take the wheel a good few miles away to get a new tube fitted as there seems to be nowhere that does it locally where I live. All's well now. Seen one wheel for £50, used but new ones are £99! Ouch... Might put some of that gloopy stuff in the valve now as a preventative measure.
doggone
PostPosted: 13:18 - 22 Apr 2009    Post subject: Reply with quote
Tubes can be fixed fairly easy yourself if you can get the tyre off and on again.
You want a proper repair kit not the bike type ones.
This sort of thing might suit because you get gas cartridge to inflate anywhere.
https://www.poweredadventure.co.uk/proddetail.asp?prod=bi_rem002
Most cars are on tubeless but lots of things still have tubes that need fixing e.g.agricultural vehicles and trailers.
You can put together a kit of your own but if you only get one or two a year don't go mad because the solution goes off after 2 or 3 years once opened.
BanditsHigh
Worse than a woman
PostPosted: 13:19 - 22 Apr 2009    Post subject: Reply with quote
Gloop/tyreweld will not work with a tubed tyre, they are for tubeless only Thumbs Up
Kal
PostPosted: 13:33 - 22 Apr 2009    Post subject: Reply with quote
I had an entire second bike and went through a stage of punctures (local scrotes I think given other vandalism) - I used to switch the rears over all of the time.
At worst you'll never need it again and will eBay it when you sell the bike.
Kal...
neil.
PostPosted: 13:38 - 22 Apr 2009    Post subject: Reply with quote
Getting the tyre off that wheel by hand looks like a royal pain in the backside TBH. Only cost me £10 to get a new tube fitted. Would have been £25 if they had to take the back wheel off and put it back, so I did that myself. Amazing machine they use to get the tyre off, did the whole job in 5 minutes flat! I used to have this Slime stuff in my bicycle inner tube that would seal punctures so there might be something suitable for me. Gonna get on Google methinks! Thanks for all the advice folks. Karma
ttr
PostPosted: 17:23 - 22 Apr 2009    Post subject: Reply with quote
If it's tube type, keep a spare tube and get some tyre levers. Once you get the technique it is actually stupidly easy, though there is a bit of a knack to it as I found out Laughing
GS125-> NT400->VFR400->CRM250->Z750 + GS125->NTV650 rat + VMX1200->GSF600 + GPz550
Kal
PostPosted: 17:36 - 22 Apr 2009    Post subject: Reply with quote
Having some lube around helps... Although you do get some odd looks in Wilkos if you are buying more than three tubes of KY Jelly.
Especially if you purchase a selection tools at the same time...
Kal...
ttr
PostPosted: 17:37 - 22 Apr 2009    Post subject: Reply with quote
I found talcum powder pretty good.
Have heard that wd40 works well too, but I'd be dubious without a rimlock, which I guess a ybr wont have.
The last post was made 17 years, 166 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 2.63 - MySQL Queries: 13 - Page Size: 80.03 Kb
