exhaust baffles
speedjunkie20...
PostPosted: 20:59 - 23 Apr 2009    Post subject: exhaust baffles Reply with quote
Ok so my exhaust is making a really loud rattling noise while im riding my ped,
I spoke to a garage and they said its my baffles have gone and the only solution is a new exhaust. The exhaust is a leo vince zx on a gilera storm. Is this really the only option, other people I have spoken to have said that it isnt.
MaybeGuy
PostPosted: 21:06 - 23 Apr 2009    Post subject: Reply with quote
the baffles are in the end can. a new one is about a tenner. you can fix them yourself EASILY.
the mechanic is a liar. they all are.
speedjunkie20...
PostPosted: 21:12 - 23 Apr 2009    Post subject: Reply with quote
I have a drill and other tools, just im not sure exactly what im doing to remove the baffle or anything. Is it safe to ride it as it is? What am I actually looking for as I dont even know what a baffle looks like and is it possible to take it out completely or will it reduce performance. +
Mr.Ormes
PostPosted: 23:22 - 23 Apr 2009    Post subject: Reply with quote
not sure on your knowledge of bikes, however i will explain fully.
the exhaust should be in 2 parts to your bike...
typically on peds that is...
expansion chamber/manifold - bolted to your head/barrel of the bike...and is the biggest part of your exhaust. make sure this is securely fastened to your engine via springs/bolts
End can/Silencer -this is the smallest part of your exhaust which will contain a small perforated tube (core), which should have what might look like fiberglass woll wrapped around it.
unravel the old fabric from the core, clean it up with a wire brush, and make sure all the holes are clear and open.
Once they are you can re-wrap the core with baffles (can be bought from most motorbike shops for under a 10ner) [some people wrap there core with wire wool first] but i just wrap the baffles around my core, fairly tight, so it is just slighley larger than the inside diameter of the exhaust shell. re-insert then re attatch the core to the manifold part of the exhaust (usually 2-3 bolts)
easy job, no more than 10-20 mins.
DT 125 1995
Thumpstar 120
Suzuki ZR 50
Mr.Ormes
PostPosted: 23:34 - 23 Apr 2009    Post subject: Reply with quote
I Am Drunk and didnt think i explained it that great, so i drew it on paint for you! Thumbs Up
https://img172.imageshack.us/img172/8460/forumctp.png
DT 125 1995
Thumpstar 120
Suzuki ZR 50
speedjunkie20...
PostPosted: 14:08 - 24 Apr 2009    Post subject: Reply with quote
Its got baffles in the expansion chamber and these are the ones that have gone...
PostPosted: 15:41 - 24 Apr 2009    Post subject: Reply with quote
If this is the case, get an angle grinder, open up the expansion chamber remove the baffle and then give it to a welder to seal back up.
The last post was made 16 years, 247 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 53.21 Kb
