| clancy |
 clancy World Chat Champion
| iooi |
 iooi Super Spammer
 Posted: 19:56 - 24 Apr 2009 Post subject: |
Take the drain plug out.......
Too much oil is as bad as too little.
Make sure when you fill up the bike is on level ground.
If in doub't empty it all out and put the correct amount in (its usually written on the side by the filler hole) ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| clancy |
| Itchy |
 Itchy Super Spammer
 Posted: 20:09 - 24 Apr 2009 Post subject: |
It should be at the lowest point in the engine, another method without using the sump plug is to siphon it out via the fill hole which some people use for seized sump plugs. Its not as good as the crud in the bottom of the engine stays in the engine till it gets caught by the filter.
Undoing the sump plug is easy , be wary about overtightening it though however putting it back in while it is gushing oil out is difficult.
If you do use the sump plug , lean the bike over to one side and you can moderate the outward flow and not lose all the oil in the process.
Or you can of course just drain all the oil out do up the sump plug and put the oil back in (minus the excess amount you put in). ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| clancy |
| Itchy |
 Itchy Super Spammer
 Posted: 20:31 - 24 Apr 2009 Post subject: |
Pass I don't know how much oil goes into the gear box, you'll have to ask a dealer or look in your manual , it being 2 stroke confuses it due to 2 stroke oil tank and gear box oil tank. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| clancy |
| Itchy |
 Itchy Super Spammer
 Posted: 20:58 - 24 Apr 2009 Post subject: |
Riiiiiight
The Reiji RS2 Matrix uses the Aprillia RS50 engine the AM6 my RS50 manual here says that the AM6 engine takes 820cc of gear box oil. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| clancy |
| Kickstart |
 Kickstart The Oracle
| clancy |
| Kickstart |
| clancy |
| Kickstart |
| clancy |
| 400bandit |
 400bandit World Chat Champion
| clancy |
The last post was made 16 years, 251 days ago. Instead of replying here, would creating a new thread be more useful? |
