| teknicz12 |
 teknicz12 L Plate Warrior
| MarJay |
 MarJay But it's British!
 Posted: 21:50 - 26 May 2004 Post subject: |
Erm Triumphs and Suzukis won't start without the clutch being pulled in even in neutral....
Don't worry at all about the bike not wanting to start unless the clutch is pulled, it sounds normal.
If the engine won't turn over then you might have some major engine damage. Perhaps a dropped valve or something equally nasty.
More info on the bike might help a bit too!  ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
| Kickstart |
 Kickstart The Oracle
 Posted: 22:26 - 26 May 2004 Post subject: |
As MarJay says, Suzukis will not start unless the clutch is pulled, and plenty of other bikes will lock the starter motor out when you are in gear unless the clutch is pulled.
The problem with it turning over could easily be a hydraulic lock. Take the plugs out and then try to turn the engine over (but with the ignition off just in case it is full of petrol which might otherwise spray out and ignite). If the bike has been stood for a while then it is quite likely that the carbs up gunged up, so when the petrol is turned on when you have tried to start it, the fuel has just run straight though the carbs into the inlets.
| teknicz12 |
| MarJay |
 Posted: 13:34 - 27 May 2004 Post subject: |
Sounds like good news. SV650's are absolute cracking bikes!  ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
The last post was made 21 years, 305 days ago. Instead of replying here, would creating a new thread be more useful? |
