Engine bars connecting with tarmac ?
kawakid
PostPosted: 23:15 - 23 Apr 2009    Post subject: Engine bars connecting with tarmac ? Reply with quote
On my ER6, I have fitted engine bars.crash.
However I am concerned with going for a full lean, where the pegs would normally go down. I am concerned with the consequences of the bars touching the road.
Does anyone know the outcome?
Because as I look at the bike , I think the bars will go down before the pegs. (Is it going to flip me?, or just grind?)
(Prior to the ER6, I had an ER5, but that had R&Gs, so not a problem, the same with my Z750 )
I don't really want to take them off, because I think they could save the bike in a slide.
I've a twin and a 4.
tatters
Exxon Valdez
PostPosted: 23:20 - 23 Apr 2009    Post subject: Reply with quote
Should just grind on the road surface if they do only problem would be if they catch or dig in on a poor surface, some BMW R series riders have been known to grind there rocker covers on the road.
Flip
I'm sure the pegs will touch before the bars. However, I think you should find out & post up the results. Thumbs Up
kawakid
PostPosted: 17:12 - 24 Apr 2009    Post subject: Reply with quote
Might just have to try it, have been a bit worried.
iooi
PostPosted: 20:50 - 24 Apr 2009    Post subject: Reply with quote
I would be very surprised if engine bars would hit the ground through normal usage.....
You have fitted them the right way Laughing
Would be a nasty shock, as unlike foot pegs they will not rise up and give. More likely to pivot the bike and spit you off.
Itchy
PostPosted: 21:05 - 24 Apr 2009    Post subject: Reply with quote
You could always stick sliders on them with a ski sort of profile so that they can't / won't dig in to the ground a few plastic milk bottles cut up should make a decent enough and cheap to wear shape I suppose, I very nearly got the crash bars down on the Africa but then I realised I fit them wrong and they drooped down a fair bit.
kawakid
PostPosted: 11:12 - 25 Apr 2009    Post subject: Reply with quote
Yeah they are fitted correctly, but they do appear lower than the pegs. But then I am not sited on the bike.
I do like to lean though, I was always scrapping my pegs and toe sliders on my other bike.
PostPosted: 11:18 - 25 Apr 2009    Post subject: Reply with quote
I ground right through the alternator casing on my xj1100 - didn't pitch me off Very Happy
PostPosted: 11:42 - 25 Apr 2009    Post subject: Reply with quote
Similarly, I've occasionally got racing-rearsets down on track (solid) and haven't had a problem. Engine bars are less likely to dig-in too, but I wouldn't make a habit of it on the road, however should be fine touching down gently if you're going just that bit faster than the last time you took the corner.
TheDonUK
PostPosted: 11:45 - 25 Apr 2009    Post subject: Reply with quote
I used to have engine bars on my Bandit, grinded them along fine, as someone said potholes would not be fun..
Finglonga
PostPosted: 12:32 - 25 Apr 2009    Post subject: Reply with quote
Remember though pegs will lift the back wheel up first . . No biggie. But engine bars if they touch down will take the weight off the front wheel.
Andy Sez....
F.Y.Y.F.F.
yen_powell
PostPosted: 12:59 - 25 Apr 2009    Post subject: Reply with quote
Bolt some little shopping trolley wheels on the end of them, problem solved! Very Happy
XT1200Z and a DR350 in bits
Itchy
PostPosted: 13:03 - 25 Apr 2009    Post subject: Reply with quote
That actually reminds me of a comic I saw years ago where motorbikes had 3 wheels , two in the normal place and a large one supported by an A frame which the rider sits in between , sort of like a E-3 Hawkeye or other Awacs aircraft.
Such that if you lean right to the limit and beyond the wheel above your head will touch the tarmac first preventing you from falling off.
Charlie
PostPosted: 13:12 - 25 Apr 2009    Post subject: Reply with quote
I was out on a ride with some of the guys off xrv.org.uk and we where going over hart side pass (best road ever) and experienced an Africa twin get its sump guard down... needless to say the rider is slightly mad Laughing
I think you will be fine, the first time it will scare shit out of you I bet.
Then again following my Dad when he is on his Transalp and watching his metal mule panniers look centimeters from touching out is quite scary. Although do seem to keep tucking under Thinking
Ade
PostPosted: 13:32 - 25 Apr 2009    Post subject: Reply with quote
There are 3 wheeler designs and a bit of a write up in this weeks MCN if it interests you Smile
PostPosted: 11:30 - 26 Apr 2009    Post subject: Reply with quote
I ground the engine bars away on the hire bandit I had, It's abit worrying the first time it happens just be prepared for it.
The last post was made 17 years, 155 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 1.23 - MySQL Queries: 13 - Page Size: 91.4 Kb
