not so wee :(
Wingchunal
PostPosted: 13:03 - 13 Jul 2002    Post subject: not so wee :( Reply with quote
Just coming to a roundabout going straight on an wooooop bike has skidded out Sad had to drive it home it first gear!
Need new indicator , new gear leaver and stickers Sad and the fairs cracked where the indicator joins Crying or Very sad Crying or Very sad Crying or Very sad
PostPosted: 13:08 - 13 Jul 2002    Post subject: Re: not so wee :( Reply with quote
nasty.... probably cos you posted 'will I ever got off my bike' ... that's gotta be asking for trouble Confused
Did the front or the back go?... sounds like you'll at least be able to get it ridable without much effort.
Wingchunal
PostPosted: 13:14 - 13 Jul 2002    Post subject: Reply with quote
The back went and i slid on my left side f*cking mk roundabouts, how much u rekon it will cost me?
PostPosted: 13:32 - 13 Jul 2002    Post subject: Reply with quote
depends how you want to do it up ... Ie looking good as new or just rideable:
Indicators:
pair of mini indicators for around £10
Gear lever:
Hopefully from a breakers or non-oe manufacturer £5-£20, probably looking at around £30 for an orginal... though not sure about that.
If it's just bent, you might be able to bend it back... thouigh I tried doing that on my (front) brake lever on my klr and just snapped the end off Confused
Fairing & Sitckers
£Loads for a new fairing or get some araldite and paint/sticker over it. Stickers shouldn't be *too* much (if available).
M1ke
Ped Boi
Unlucky mate Crying or Very sad
New fairing will be a bit pricey, about 100ish upwards i would say depending on which bits you replace. have no idea about the gearing problem.
I was in halfords the other day and they had this stuff for sale that fills in cracks and deep scratches on *FIBERGLASS* im not sure if the fairings on nsr's are plastic?
Wingchunal
PostPosted: 13:40 - 13 Jul 2002    Post subject: Reply with quote
The fairing is probably cracked about 1 1/2 inch up and down of the indicator, ill give some places a ring in amin see what its gonna be £££ Crying or Very sad
TiN
Pocket Tin
PostPosted: 14:15 - 13 Jul 2002    Post subject: Reply with quote
Bah, unlucky mate Sad
Did you damage your clutch lever?...or gear selector?...I'm assuming that you only had to ride home in 1st because of this? (and not 'cos of any engine damage etc...?)
By the sound of it, you can probably just repair the fairing, there are a few plastic repair kits out there...or you can use G's method...I really don't think that it'll be worth replacing the panel (but then again, I haven't actually seen the damage)...
...you can probably order the official stickers through your local dealer...but expect to wait...
Take it easy mate...
Tin
Wingchunal
PostPosted: 14:49 - 13 Jul 2002    Post subject: Reply with quote
Its the gear selecter thats snapped off, clutch leaver is fine(except a few scratches! Rang around a few places and there gonna call me back on monday Crying or Very sad with the prices. Im assuming the engine is fine Confused fingers crossed! Ill probably just patch up the fairing its not mega damage ill post a pic up soon as i find my digi cam and see what you rekons best!
Annabella
Like a person, only smaller
PostPosted: 16:02 - 13 Jul 2002    Post subject: Reply with quote
Bad luck man!
If the fairing is only cracked you should be able to ghet it welded pretty cheaply..... Good luck!
Avast! Pirates ahoy!
I did Cadwell! Very Happy
Demonic69
The Pink Rhino
PostPosted: 16:10 - 13 Jul 2002    Post subject: Reply with quote
Welding a fairing??? Hmmmmm.
The stuff from Halfords is good. Worked on my NSR when I re-sprayed it.
Check the entire shaft for the gear selector though, make sure it aint bent inside.
Back on a Blade. Just feels so right.
craigT19
Jolly Green Giant
PostPosted: 18:04 - 13 Jul 2002    Post subject: ... Reply with quote
the curse strikes again Sad
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
TiN
Pocket Tin
PostPosted: 18:06 - 13 Jul 2002    Post subject: Reply with quote
Yup, plastic welding...usually involves a heat gun with a special nozzle, and some plastic rods...
Tin
Wingchunal
PostPosted: 18:17 - 13 Jul 2002    Post subject: Reply with quote
Right this was canell's have quoted me on parts Confused
Indicator left front £18.45
Gear leaver £27.01
Stickers £76.18<<<< must be made out of gold!
Dan
PostPosted: 22:26 - 13 Jul 2002    Post subject: 1 Reply with quote
i thought u had only just got ur bike?
McJamweasel
BCF Junkie
PostPosted: 23:51 - 13 Jul 2002    Post subject: Reply with quote
For your stickers go to www.morgandesigns.com - theyre much cheaper.
Wingchunal
PostPosted: 10:09 - 14 Jul 2002    Post subject: Reply with quote
I have only jsut got my bike dan Sad
PsychoHippy
Jammy Git
PostPosted: 11:27 - 14 Jul 2002    Post subject: Reply with quote
Yeah, plastic welding is probably the way to go with the fairing, should cost much more than £30 or so. They did it on my V-Raptor's tank cover, and you can't see it, which is saying something when you see the shape of the tank!
curryhead
PostPosted: 22:49 - 14 Jul 2002    Post subject: Reply with quote
if the fairing is wrecked then why not turn the bike into a streetfighter it depends on individual taste. you could have a different looking decent nsr for the cost of the repairs?
take it easy, watch out for blind car drivers!
Demonic69
The Pink Rhino
PostPosted: 10:38 - 15 Jul 2002    Post subject: Reply with quote
£18.45 for one indicator? The Anodised sets are only £15.
And the gear lever's expensive. Even for Carnells.
Ryan
PostPosted: 10:47 - 15 Jul 2002    Post subject: wingchunel Reply with quote
hey just realised after watching the classic races at olivers mount during cock of the north (a set of road races b4 u ask) that there's bad ass old bike called the wingchunel that makes the best sound i have ever!!! heard, its a v-twin with two huge exhausts firing the tune. am i right?
Wingchunal
PostPosted: 18:10 - 15 Jul 2002    Post subject: Reply with quote
Hmmmmmm i dunno but my name aint after no acient bike Razz it wing chun - kungfu al- alex Twisted Evil
The last post was made 23 years, 240 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.31 - MySQL Queries: 13 - Page Size: 106.59 Kb
