underfilled oil gsx750f?
flumpy7
PostPosted: 11:30 - 29 Apr 2009    Post subject: underfilled oil gsx750f? Reply with quote
Hi all, me again....
Changed the oil and filter on my 750 katana today. Filled it to between the lines on the sightglass then ran the engine for a few mins (didnt fill it right to the top line as last time i did that, when i ran the engine, it appeared overfilled). When i stopped the engine and waited for a while to let it all drain back down, the oil was below the bottom line (in fact couldnt really see any oil). Obviously i immediately topped it up again to between the lines,but i was wondering could i have done any damage for the few mins the bike was running. The oil warning light didnt come on whilst the engine was running so i should be ok, right? Why such a difference between before and after running the engine?
Thanks again
Itchy
PostPosted: 11:43 - 29 Apr 2009    Post subject: Reply with quote
Because oil does more than sit in your sump in that it gets sucked up through the pump and into various bits of the engine where it clings thus lowering your oil level. I tend to put it right to the upper line once it has been run it goes down a bit...
Heh I hate oil changes though in that when you do start the bike the red oil warning light stays on for a second longer than normal as the pump has been drained.
Feasty
PostPosted: 12:56 - 29 Apr 2009    Post subject: Reply with quote
I have no idea if this is related or similar to my bike. But in my Honda SLR650 manual it states that when I change the oil, to firstly fill it with 1L of oil before running the bike for a couple of mins and then add the remainder. This is because the oil tank is slightly seperate from the rest of the engine (inside the frame in fact) and so the oil needs drawing into the engine before the correct amount of oil can be added - otherwise I'm assuming it'd overflow from the frame/tank!
Previous: Aprilia Habana Retro 50cc (beauty), Yamaha SR125 (fell apart), Honda XR125 (nippy little commuter), Honda SLR650 (Geewhizz), Yamaha Diversion 900S (Smoooooth) written off courtesy of a stupid escaped horse.
(7 year gap), BMW F650 (Relaxing ride). Aprilia Caponord ETV1000 (Big and bold). Yamaha FZS600 (got me in trouble too quick!).
Current: Yamaha TDM 900 (Comfy, light but big, power when needed).
yen_powell
PostPosted: 13:12 - 29 Apr 2009    Post subject: Re: underfilled oil gsx750f? Reply with quote
Thanks again
Don't forget you were filling that new oil filter up the first time the engine ran.
XT1200Z and a DR350 in bits
flumpy7
PostPosted: 21:14 - 29 Apr 2009    Post subject: Reply with quote
so you guys think it will be ok then?
yen_powell
PostPosted: 21:38 - 29 Apr 2009    Post subject: Reply with quote
I always put in the amount of oil it states for an oil and filter change and I usually have to do a bit of topping up after the engine has had it's first startup.
The last post was made 17 years, 149 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 49.32 Kb
