Swingarm socket - how to make one?
GSXReater
PostPosted: 22:01 - 29 Apr 2009    Post subject: Swingarm socket - how to make one? Reply with quote
Ok i need to make one of these from a normal socket:
https://i147.photobucket.com/albums/r307/tdcfrank/Swingarm%20Socket/20071220_IMG_0001.jpg
So whats the best way to make one? Using a dremel (which i dont have)? Or what can i use?
Thanks.
Skudd
PostPosted: 22:07 - 29 Apr 2009    Post subject: Reply with quote
Angle grinder, about £15 from DIY shops. Just watch your fingers.
GSXReater
PostPosted: 22:16 - 29 Apr 2009    Post subject: Reply with quote
Thought of that, and i have one but didnt think it would be accurate?
Any more ideas, i just want to do it once and not have to buy lots of sockets.
Thanks.
Skudd
PostPosted: 22:20 - 29 Apr 2009    Post subject: Reply with quote
Depends on how handy you are with a grinder. Obviously clamp either the grinder or the socket down then just grind away. I have done all sorts of things with my trusty grinder.
PostPosted: 00:32 - 30 Apr 2009    Post subject: Reply with quote
Paint the end of the nut then push the socket onto it, this would give you a template where to cut.
PostPosted: 01:00 - 30 Apr 2009    Post subject: Reply with quote
Honda part number: 077160020203
Reversable, 1/2" drive, impact grade, lock nut wrench, 26mm and 30mm. £21 from David Silvers.
TOTALLY worth the money. Take it and the bike to someone with an air impact spanner (eg. local tyre fitters). Nut will be off in less than 5 seconds then put it back on and nip it up tight enough to get you home using a hand tool. Remove at your leisure.
https://www.davidsilverspares.co.uk/graphics/parts/077160020203.jpg
The last post was made 17 years, 174 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.26 - MySQL Queries: 13 - Page Size: 48.47 Kb
