clutch or more
d-bug
PostPosted: 22:13 - 30 Apr 2009    Post subject: clutch or more Reply with quote
i have a cagiva mito mk2 1994 , when the bike is cold and i put it into gear , the bike jumps forword an stalls , just like im not pullin in the clutch an bangging it into gear , but after its warmed up it seems to be ok , but all so its a rite bitch to get into neutral even when warmed up
what might be the prob ? are the 2 things linked , or what could i try to see if it would stop ?
cheers d-bug
The Artist
PostPosted: 01:53 - 01 May 2009    Post subject: Reply with quote
Some bikes do this.
When was the last time the oil was changed? Gearbox or otherwise? I have no idea what your bike has.
When setting off from cold, just rev a little bit as you click down into gear.
Being a bastard to get into neutral is normal on some bikes. Can be signs of gearbox wear but others are just like that.
Scotsman37
PostPosted: 02:34 - 01 May 2009    Post subject: Reply with quote
A possible bent/worn gear selector.
Are you able to choose all the other gears without a problem?
Have you checked to see if you need to adjust the clutch cable or if it's already tightened to the possible max then maybe it needs replaced? Or maybe you need to oil the clutch cable, as it's not fully releasing when you let go of the clutch due to possible build up of crap/rust?
PostPosted: 04:13 - 01 May 2009    Post subject: Reply with quote
Where is the biting point on your clutch with regards the to the lever? if it is close to the bar adjust it outwards abit. Changing the oil is a good idea too.
d-bug
PostPosted: 15:22 - 01 May 2009    Post subject: Reply with quote
i have just done a oil change on the bike , and a topend rebuild , the clutch leaver bites around half way out , and i can get every other gear no probs but neutral is the bugger , but gotta say its not all the time but most of the time a bugger to get into neutral , and i have to end up doin it by hand an its bloody stiff ,
hope this helps guys
cheers d-bug
Finglonga
PostPosted: 10:39 - 02 May 2009    Post subject: Reply with quote
Stick the bike in gear . . . roll it forwards and back WITH the clutch pulled in to free the plates up. Then start as usual, should be much better then. All multi plate wet clutch bikes usually do it due to the oil being more viscous when cold.
Andy Sez....
F.Y.Y.F.F.
MaybeGuy
PostPosted: 11:40 - 02 May 2009    Post subject: Reply with quote
7 speed MK2s are notoriously cuntish to get into neutral. dont worry about it. who needs it anyway?
clutch thing could be stuck plates. was it standing for a long time at any point with or without oil?
d-bug
PostPosted: 15:42 - 02 May 2009    Post subject: Reply with quote
yer the bike was stood round for 3 months before i got it and a year on top after i got it home , then i done a oil change on it an the oil was like gack .
MaybeGuy
PostPosted: 15:45 - 02 May 2009    Post subject: Reply with quote
probably why then. take the clutch plates out, seperate them and soak them in oil for a few hours.
The last post was made 17 years, 53 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.95 - MySQL Queries: 13 - Page Size: 59.84 Kb
