NSR 125 assistance
harrisondavie...
PostPosted: 09:24 - 03 May 2009    Post subject: NSR 125 assistance Reply with quote
Hi,
Perhaps someone can assist.
I hit a roundabout from a dual carriageway, I am unable to continue so have to pause as usual.
Trouble is as I'm taking off again I'm in 1st, with good biting point and good revs, the bike just judders, and revs drop below it's ticking over point, sounds like it's conking out, bunny hops and I end up in the middle of the roundabout having to restart the engine and off it goes, sometimes after two attempts at this.
Oh and I should add even if I have full throttle, makes no difference, just kinda dies on me...yet she works admirably in every other situation.
Any ideas?
Harrison
alains
PostPosted: 09:59 - 03 May 2009    Post subject: Reply with quote
how hard you hit that roundabout ?
did you do an inspection about the damages ?
can you push & roll the bike ?
it's difficult to tell you with so few reports
harrisondavie...
PostPosted: 10:05 - 03 May 2009    Post subject: Reply with quote
Hi,
I guess my explanation wasn't good.
I didn't actually hit the roundabout, it just means I arrived at the roundabout in a normal flow of traffic and have to shift down to 1st before moving off again.
Then the above happens, quite randomly, and it only seems after I've topped 40+ MPH before arriving at the roundabout.
Yes I can push/roll the bike.
Regards,
Harrison
alains
PostPosted: 11:07 - 03 May 2009    Post subject: Reply with quote
check coil primary terminal (black/yellow wire) and at the other end on the 4 wires connector at the CDI . if your rev counter does fancy movements it's there
fit a new plug (i recommand BR9EIX instead of BR9ECS which is bull shit)
check HT lead and cap . this can be tested with a multimeter
download my file https://www.geneva-racing.ch/~alains/NSRtips.doc and look for ignition bug
the other possibility could be a fuel line problem and in this case you must clean : tank tap (because it's a filter inside) , carb strainer , float chamber
and by the way , clean and slightly oil the air box foam filter
harrisondavie...
PostPosted: 13:46 - 03 May 2009    Post subject: Reply with quote
Thank you I will let you know how it goes
Harrison
salty21
PostPosted: 15:44 - 03 May 2009    Post subject: Reply with quote
just out of interest alains, if you were stranded in the middle of nowhere needing a spark plug and some kind passer by offered you a BR9ECS would you take it greatfully and put it in your bike or would you tell them its bull shit and start walking Laughing
alains
PostPosted: 18:48 - 03 May 2009    Post subject: Reply with quote
this is why i had all the time a new one with me . it's like ridding a bike without a puncture kit
The last post was made 17 years, 49 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 2.21 - MySQL Queries: 13 - Page Size: 52.15 Kb
