wood riff key?
stuart92
PostPosted: 22:09 - 03 May 2009    Post subject: wood riff key? Reply with quote
right i have my derbi senda 96
and the keys coming out even with the nut on the out sie being ubber tight
this bike it more hassle than worth :/
oh well not long till my 125 4 stroke Smile
stuart
derbi senda 50cc 1996 (yes it is old)
finpos
PostPosted: 22:48 - 03 May 2009    Post subject: Reply with quote
The key should not be holding anything, it's only there to make sure the flywheel is positioned correctly. If it's working loose, then either the key or the keyway is worn/battered to hell. As long as the flywheel is positioned correctly and is staying where it is, then everything is ok.
If the flywheel is moving on the end of the crankshaft, then you've got all sorts of other problems that are nothing to do with the key.
f.
stuart92
PostPosted: 23:50 - 03 May 2009    Post subject: Reply with quote
think it might be, the bit where it sits looks a bit shagged
_sketch_
PostPosted: 08:14 - 05 May 2009    Post subject: Reply with quote
Same happned to me, The grove was shagged - Ring around a few placed for a Magneto - I found one for my KMX for £50 - Kawasaki wanted £250!
A sucker for 2 strokes
Cagiva Supermoto project
Finglonga
PostPosted: 12:47 - 05 May 2009    Post subject: Reply with quote
It's woodruff Key. Wink
Andy Sez....
F.Y.Y.F.F.
PostPosted: 21:27 - 05 May 2009    Post subject: Reply with quote
Also remember to degrease both parts of the taper with solvent before fitting. Any oil on there and it'll just spin up.
The last post was made 17 years, 67 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 2.53 - MySQL Queries: 13 - Page Size: 51.26 Kb
