Front brake light switch (NSR)
Nixon
PostPosted: 18:33 - 03 May 2009    Post subject: Front brake light switch (NSR) Reply with quote
My front brake switch has started being dodgy, when i pull the brake it will trigger the lights but then they go out as you pull the lever in closer.
Its like it only works at a specific point
so is a front switch easy to repair/replace and is there anything i should be aware of before i attempt it?
mattsmith95
PostPosted: 00:19 - 04 May 2009    Post subject: Reply with quote
A repair isn't worth it, bottom line is the switch is knackered and you will be better off replacing it, they are quite cheap and you don't have to panic about genuine parts on this.
I've just replaced one recently myself, easy to fit but to get the old one off you will need a decent Phillips screwdriver and some WD40 because that little bolt will be a bugger to remove and you could damage the head.
alains
PostPosted: 00:31 - 04 May 2009    Post subject: Reply with quote
it's around 10 quids https://www.davidsilverspares.co.uk reference : 35340-MM5-600
takes less than 1/4H to replace
PostPosted: 05:53 - 04 May 2009    Post subject: Reply with quote
Before buying anything try squirting some WD40 in there.
Fisty
PostPosted: 08:28 - 04 May 2009    Post subject: Reply with quote
As chris said, this often is a cure for dodgy brake switches.
Fatter and faster than Fret
alains
PostPosted: 08:58 - 04 May 2009    Post subject: Reply with quote
this wont work on this switch and i think the WD40 will cause more damage
Fisty
PostPosted: 09:15 - 04 May 2009    Post subject: Reply with quote
For why?
alains
PostPosted: 10:17 - 04 May 2009    Post subject: Reply with quote
plastic will melt a bit
Fisty
PostPosted: 11:42 - 04 May 2009    Post subject: Reply with quote
Erm, no it wont. I have used WD40 on EVERY connection on my bike after a rebuild. Hasnt melted a thing.
It will melt the plastic if you ignite it mind you.
alains
PostPosted: 12:38 - 04 May 2009    Post subject: Reply with quote
never say that to an electrician . it's a french proverb which says :
dont tell that to a wooden horse , it will kick you
Fisty
PostPosted: 12:45 - 04 May 2009    Post subject: Reply with quote
Have a look at the WD40 website, "DISPLACES MOISTURE: Because WD-40 displaces moisture, it quickly dries out electrical systems to eliminate moisture-induced short circuits. Turn the power off before you spray"
https://www.wd40.co.uk/index.cfm?articleid=1519
Been using the stuff for years, never had a problem with it. Infact used in on a brake light switch on monday.
If you are worried about it "melting" plastic, use a dedicated contact cleaner/lube.
If they fail, a new switch it is!
The last post was made 17 years, 49 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 73.54 Kb
