| jp14 |
 jp14 Nova Slayer
 Posted: 18:01 - 03 May 2009 Post subject: Failed my MOT, worth me trying to fix it myself? |
My yamaha rxs100 failed it's MOT the other day due to head races being worn and front fork seals leaking (among a couple of other things) is it worth me trying to replace the head races and seals myself with some knowledge of using a spanner and a haynes manual, or paying over £100 for the garage to do it?
Thanks |
| KevTM |
 KevTM World Chat Champion
 Posted: 18:42 - 03 May 2009 Post subject: |
Not really that difficult unless you run into a problem. I say attempt it yourself, best way to learn
One of the forks in one of my bikes was leaking, one of the previous owners had made a right mess replacing the seal.. there was parts missing and he hammered a washer in (instead of using the proper clip), ruined the inside of the fork leg  |
| creature |
 creature Derestricted Danger
| Scotsman37 |
 Scotsman37 World Chat Champion
| mattsmith95 |
 mattsmith95 Traffic Copper
| chris-red |
| mikey 2659 |
 mikey 2659 Borekit Bruiser
 Posted: 01:38 - 04 May 2009 Post subject: |
cut off the cones carefully with an angle grinder and knock out the cups ,buy a set of taper roller bearings and drift in/on with the old parts,easier(no balls to lose),longer lasting,feel nicer,probably cheaper than yamaha prices.pack with suitable grease and DO NOT overtighten.both of my previous rxs were notchy on originals before 10k.it may seem like overkill but i got the bearings from an engineering suppliers cheap,he measured up the old parts,or you could try m and p.the fork seals are fairly easy to do,take care not to damage the leg when removing the seal,i used a large, close fitting socket back to front on an extension bar to drift the new ones in.when disassembling undo the top pinch bolts only to make removing the top cap on the leg with a 14mm allen key or similar tool easier.there is a spring under compression so undo carefully.i fitted motorcross style gaitors to protect the chrome legs from chips and corrosion. |
| jp14 |
 jp14 Nova Slayer
 Posted: 16:55 - 04 May 2009 Post subject: |
mm, it sounds all pretty daunting, I think it'll be worth the extra £40 if the MOT station does it cos i don't need to pay for the MOT again so thats minus 28 quid. I can sort out the little problems my self relitivley easily.
And by the sounds of it i'm going to need some specialist equipmet so... I think, this time, the system wins..
Cheers for the advice  |
| dynamec |
 dynamec L Plate Warrior
| mikey 2659 |
| dynamec |
| mikey 2659 |
| clancy |
 clancy World Chat Champion
| 1016.5 |
 1016.5 Renault 5 Driver
| dynamec |
 Posted: 21:19 - 05 May 2009 Post subject: |
| mikey 2659 |
| neatbik |
 neatbik World Chat Champion
| Mac_Black |
 Mac_Black World Chat Champion
 Posted: 15:12 - 06 May 2009 Post subject: |
I can also back up Nick and Martin, the point is that unless you are fully aware of what it is you are doing,
what belongs where and how different components behave and interact with each other then something as simple as overhauling forks could become very a very dangerous and expensive task.
I've recently overhauled my forks which are USD's,
replaced both of the races, top and bottom bearings and seals.
There are quite a few specialist tools that you will either need to by or fabricate, quite often the haynes will tell you that you need them, just not what they are.
Finding these tools can be a nightmare and is going to cost and your going to need to be very accurate if you have the skills to make your own.
Another point is about working safely on the bike,
for this sort of job you'll need the bike supported on either axle stands or by a winch, a ramp with a tie would be a very good idea,
you have to be very careful how you treat the forks and sometimes it can get quite frustrating especially if they've been bodged.
You should fully compress the forks before removal and allow them to fully extend for example to take the tension out of the spring, you should then loosen the top cap with only the bottom pinch bolts tight whilst still on the bike.
In this stage alone there is so much that could go wrong if you don't do things in the correct way, for instance there is the possibility that you could destroy the top cap and outer tube threads, failing to unload the tension on the spring can have the top cap shoot of at a devastating speed which WILL cause damage and injury.
Doing this sort of stuff at college in a professional and monitored environment I have to see that even we see allot of mistakes made and I can say I've made a few myself when I haven't been concentrating.
What Martin told jp14 was for jp14's own benefit so take the advice.
 Posted: 17:01 - 06 May 2009 Post subject: |
It is however an RXS100. It is a motorcycle most adults would be perfectly capable of lifting totally off the ground by themself (every time I take my H100 out of the lockup, I pick it up and carry it sideways 4 feet).
Buy a haynes manual. Read through the instructions, have a crack. A garage will almost certainly charge you more than the bike itself is worth to do both those jobs.
One thing I'd definately do is not waste my time fannying about with special tools and bits of broom handle taking the bottom fork bolt out. Take it to a nearby garage and ask them nicely to remove it for you using their air impact wrench. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| jp14 |
 jp14 Nova Slayer
 Posted: 22:21 - 10 May 2009 Post subject: |
I've ended up taking it into the garage; I know I would have just got frustrated with it and probably broken some more stuff, so I gave in .
But.... it is not going to be ready till monday or maybe even tuesday which means I will have been a lovely sunny saturday and sunday without a motorbike !! Meaning i've had to cycle... on a bicycle!! Without an engine!!! And it's been great motorbike weather!!
Sorry, I just had to voice my frustration some how.
Thanks |
| Mudskipper |
 Mudskipper World Chat Champion
| jp14 |
 jp14 Nova Slayer
| jp14 |
 jp14 Nova Slayer
The last post was made 17 years, 161 days ago. Instead of replying here, would creating a new thread be more useful? |
