had a go at welding
salty21
PostPosted: 17:34 - 06 May 2009    Post subject: had a go at welding Reply with quote
not sure if this is the right section so feel free to move it if its not.
we had some RSJ beams to fit at work this week which needed welding together in a 'T' shape to carry two walls. We usually get the same guys who provide the beam to weld them together for us when there in position, but my boss decided we were gonna start doing it ourselves and splashed out on an arc welder today.
none of us had ever done any welding before so i offered to have a go first as it's something i would like to learn and thought it would come in very handy for lots of things.
i would like to get pretty good at it eventually and hoped some kind folks in here could give me some pointers and any usefull advice they may have such as finding the right power setting an getting the rod travel right. heres a few pics of todays practice attempts.
first attempt Sick
https://www.bikechatforums.com/files/weld_1.jpg
second attempt' a bit better but still wank Sad
https://www.bikechatforums.com/files/weld_2.jpg
i found it really difficult to see what i was doing with the mask on, obviouslyly it was better once i had it arc'ing but still struggled to see even then.
Davo
Davo To The Rescue!
PostPosted: 18:50 - 06 May 2009    Post subject: Reply with quote
Good luck, you've picked one of the hardest welding to techniques to master. Laughing
I've just finished doing an Arc welding course at college. Is well worth getting yourself booked on one cost me £150 for a 12 week course (part time evenings). Otherwise get a ton of scrap metal and just keep practicing but it is definitely worth getting some professional tuition for the basics (especially if any of these RSJ's are to be load bearing)
The technique I use is to move the electrode in a small circular motion down where you want to place the bead. (Have a look on youtube for some of the instructional videos)
On the electrode packaging it will have what current range you can use, but will ultimately depend on type of electrode, thickness of metal to be welded and your deposition speed.
You will need to get your self a warm, dry area to store the electrodes as they are very sensitive to moisture.
You'll also need a chipping hammer (to remove the slag) etc... a good ventilation system. It's also well worth getting a decent grinder to tidy up the welds afterwards (e.g. removing splatter).
If your doing it a lot I can definitely recommend getting a "react-a-lite" helmet, these will stay light (so that you can see what your doing) then darken as soon as you strike the arc.
Sorry if it's a little jumbled but hope it helps a little.
The Artist
PostPosted: 18:58 - 06 May 2009    Post subject: Reply with quote
Why did he get an arc welder if none of you could do it?
Should have gotten a mig welder. First go on one of them was easy! Within 15 minutes, I could make a decent strong weld and don't have to worry about moving your arm in as the electrode gets shorter.
salty21
PostPosted: 19:10 - 06 May 2009    Post subject: Reply with quote
i think he went for the arc welder as it was cheapest Laughing, the weld im doing is only to stop side to side movement really and has little effect on the load bearing strength as they have been cut to interlock.
when/if i get any better i want to make a frame to hold a racing seat, wheel, pedals and gear shifter for gran turismo as thats something i have wanted for ages and they cost a fortune to buy
69.9mph
PostPosted: 20:10 - 06 May 2009    Post subject: Reply with quote
That first pic is a typical first attempt, it's called pigeon-shit welding for obvious reasons Wink
Keep practising, move the stick more slowly and in a slight circular motion as you're moving along.
Robby
Dirty Old Man
So I presume you're builders or similar, welding structural materials with no experience or training, and getting paid for it.
Care to let me know the name of the company, so that I can make sure you never, ever get anywhere near my house?
salty21
PostPosted: 21:01 - 06 May 2009    Post subject: Reply with quote
in this case the weld is not structural it's there meerly to stop lateral movement the weld is in no way load bearing and will be inspected by a building inspector before being plasterboarded.
PostPosted: 21:06 - 06 May 2009    Post subject: Reply with quote
Agreed.
That first pic actually looks like a stronger weld than the second... neatness is not everything. Neatness is nice, but penetration is the key to a strong weld. Either way, as Robby says, tell me which company you work for so I can not have any work done by them.
salty21
PostPosted: 21:21 - 06 May 2009    Post subject: Reply with quote
training is for girls and gays Laughing
no but seriously if it was structural i wouldnt do it, im not sure you understand how non structural it actually is, it would not budge at all even if it wasnt welded it's more peice of mind than anything and it keeps the inspector sweet.
chrisw
PostPosted: 22:23 - 06 May 2009    Post subject: Reply with quote
Not enough power and moving to quickly, you arn't forming a 'pool' of weld.
If this is to go near a building, don't, just don't Laughing
IIRC, last time there was a thread about welding, a few pros crept out of the wood work (or should that be metal?). Put a post in general if you actually want any advise.
BanditsHigh
Worse than a woman
PostPosted: 07:12 - 09 May 2009    Post subject: Reply with quote
If it's purely to hold the beams in place, even though you say they can't move ... why not just bolt them together with a thick metal strap?
Welding is a skill, it make look ok from the outside, but as mentioned above it's the penetration that matters.
SoND
PostPosted: 20:02 - 09 May 2009    Post subject: Reply with quote
It's far too cold and you're not pushing enough filler into it. Strike the arc, let the puddle get to the size you want before you move and keep it the same size the whole way down. Practice practice practice.
The last post was made 17 years, 158 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 84.54 Kb
