How important is a fairing aerodynamically?
c-m
PostPosted: 20:36 - 07 May 2009    Post subject: How important is a fairing aerodynamically? Reply with quote
I have a ZXR750 - Now I prefer the look of the bike without the lower fairings, but I was just wondering how important they are in terms of aerodynamics?
I know the bely pan fairing on the GPZ500 was a very important aerodynamic piece, there are man stories of high speed weaves and wobbles without it.
Anyway the reason I ask is that I now have a full fairing set for my bike, all be it different colours and was wondering is its worth putting the lower panels on when travelling longer distances like 3000-5000miles.
I presume the weight will reduce fuel economy, but the fairing itself might reduce drag and hence make up for this.
Any thoughts?
The Artist
PostPosted: 20:45 - 07 May 2009    Post subject: Reply with quote
Bikes have the aerodynamics of houses. Just because they are not smooth all along. Even fairings can't make a bike anywhere near as aerodynamic as a car.
Even with fairings, they won't go that much faster.
More handling issues but even those, you will need to do high speeds.
Cue kickstart
McGee
O RLY?
PostPosted: 20:46 - 07 May 2009    Post subject: Reply with quote
Hayabusa.
Its pronounced Jixxer!
1016
PostPosted: 20:53 - 07 May 2009    Post subject: Reply with quote
Good one.... Hope you get a big response 'cos any useful information (on this subject) can only really come from first hand experience, and (as you know) results vary so much from bike to bike. Only generalising here, I would guess sub-50mph additional weight of full fairings would lower MPG but if you were cruising at 80 upwards, then surely you would see a MPG benefit. I think you are the very man for the job of doing back-to-back tests and posting results! Thumbs Up
The Artist
PostPosted: 20:59 - 07 May 2009    Post subject: Reply with quote
McGee wrote:
Hayabusa.
I suppose I should change that statement to
Bikes have the aerodynamics of houses compared to cars.
PostPosted: 21:52 - 07 May 2009    Post subject: Reply with quote
Fuel consumption would increase, the amount of weight lost will be negliable compared to the loss of aero dynamics.
PostPosted: 22:11 - 07 May 2009    Post subject: Reply with quote
Guy I know went out on a nitrous GSX1100 and went 164mph, put a fairing on it and went 191mph.
When you're looking for speed, aeros are everything!
PostPosted: 22:28 - 07 May 2009    Post subject: Reply with quote
Bikes are lousy at aerodynamics. Fairing help, but even a 'busa is pretty dire. It is aerodynamic drag and most of it comes from the back and no bike has even a vaguely clean rear end. The effort goes into the fairings as people think the fairing is important when it is really the back end that is more important.
For comparision my unfaired 1200 Bandit has about 25% more power than my faired Bimota. Through timing lights the Bandit is only a couple of mph faster.
Stability is funny. Might make a massive difference (either way). For a (car) example, the old Ford Sierra had stability problems early on. The fix was a tiny bit of trim sticking out about 1cm at most around the rear side windows.
Tricolor
PostPosted: 22:34 - 07 May 2009    Post subject: Reply with quote
There's a significant difference between a faired and naked bike. However, there's very little difference between a faired and half-faired bike in terms of drag.
The lower half of bikes are aerodynamic disaster areas. Turbulent air coming off the front wheel is the biggest problem. Large cooling surfaces don't help either.
Give me ambiguity or give me something else.
c_dug
PostPosted: 23:14 - 07 May 2009    Post subject: Re: How important is a fairing aerodynamically? Reply with quote
I've heard this several times now about the GPZ, i smashed my belly pan to smithereens on a kerb at least 6 months ago now, i managed to bend the rear mounts as well so it hasn't been replaced. I have never had any stability issues at any speeds and i've done enough high speed motorway journeys to have noticed if there was some sort of wobble or weave.
c_dug
PostPosted: 23:18 - 07 May 2009    Post subject: Reply with quote
This bike has a 50cc engine.
https://www.cybermotorcycle.com/gallery/kreidler/images/Kreidler_Van_Veen.jpg
Aerodynamics make a MASSIVE difference, even at low speeds. Otherwise they wouldn't bother bolting so much plastic to their ultra-lightweight racer.
The difference they make increases exponentially with speed. (friction is directly proportional to speed squared)
My H100 goes 5mph faster if I take one hand off the bars and put it behind my back. That's a 7% increase in top speed.
PostPosted: 23:20 - 07 May 2009    Post subject: Re: How important is a fairing aerodynamically? Reply with quote
c_dug
I've had two seperate ones (an A2 and a D) develop a disturbing slow weave that increased with speed from around 110mph upwards. It was totally abolished when I refitted the belly pan.
c_dug
PostPosted: 23:31 - 07 May 2009    Post subject: Reply with quote
meh, mines a D and ive never noticed it, i have it all the way up to 110mph and beyond on a pretty much daily basis so long as the weather and traffic allow.
Must just be an uber cool GPZ Thumbs Up
c_dug
Scotsman37
PostPosted: 23:34 - 07 May 2009    Post subject: Reply with quote
Aerodynamics - it keeps the brunt of the wind off you by reducing the drag when at speed and in return you improve the fuel efficiency of the bike. Also, it helps to deflect the rain when also at speed coming at you from the front and especially the when it's cold too.
Plus on the right bike with a smart looking design it just makes the bike look amazing !
1016
PostPosted: 06:08 - 08 May 2009    Post subject: Reply with quote
but varies massively with size of bike and what you are calling 'low' speed - the racer you include will be spending most of its time flat out? (have no idea what that might be) and so fairing will largely be shaped with that in mind?. I will stick my neck out, as haven't researched enough, and say, majority of bikes 250 upwards would show no benefit mpg or aero at sub 40mph. I look forward to reading input from people who HAVE researched. Thumbs Up
Smooth
PostPosted: 09:09 - 08 May 2009    Post subject: Reply with quote
From what I remember at uni, in general terms, in order to reduce the 'drag force' the frontal area should be reduced to a minimum, tapered and the rear end of a vehicle should either be vertical or very long and tapered. The typical coupé/hatchback is in-between these and is actually at a disadvantage compared with a like-for-like estate car.
If I remember correctly the Cd of a Transit is lower than that of a typical saloon car, but the frontal area is larger so the force resulting from drag is greater.
TDM850
c_dug
PostPosted: 09:23 - 08 May 2009    Post subject: Reply with quote
It would be almost impossible to make a vehicle in this shape but im 99% certain the most aerodynamic shape is the shape of a falling water droplet, i.e. large round frontal area and long drawn out rear working its way into a point, like so
c_dug
PostPosted: 09:34 - 08 May 2009    Post subject: Reply with quote
Drag makes a difference at low speed, but the difference increases massively with speed. At 40mph a typical unfaired bike will need about 17 lbs of thrust to overcome aerodynamic drag while a 'busa will about 15 lbs of thrust.
To put that in perspective a restricted 6 speed Cagiva Mito in top gear at 40mph has about 41 lbs of thrust (and if using the gears and down in 3rd it would have a 110 lbs of thrust).
While you can improve aerodynamics it tends to add weight, which destroys acceleration. However the weight has very little effect on top speed (a very very marginal effect on rolling resistance). Think this is the basis for the kamm tail designs of cars, as although a full tapering rear is better, once you have started to gently reduce the height at the back you have gained most of the advantages. After that you are adding weight and length for a diminishing return. This is why coupes are shaped like that.
As I understand it a large vertical rear end is pretty dire for aeodynamics. Just look at how a conventional car shape will generally keep the rear window clear of rain when moving, where an estate will need a rear wiper to clear off all the water droplets sucked round onto it.
Tear drop is pretty perfect, and to an extent used in faired bikes for top speed attempts. Trouble is stability. It will move the centre of pressure far forward , well in front of the driving wheel and centre of gravity. Makes it like trying to throw a dart backwards.
Smooth
PostPosted: 09:40 - 08 May 2009    Post subject: Reply with quote
Kickstart wrote:
Think this is the basis for the kamm tail designs of cars, as although a full tapering rear is better...
Yes, a short slope with a sharp truncation is better than a 'half-way-house' sloping tail. An effective taper needs to be significantly long which would be impractical on a motorbike.
A water-drop style vehicle:
https://vkstudio.co.uk/graphics/belly3.jpg
The wheels spoil the shape somewhat though
TDM850
PostPosted: 09:56 - 08 May 2009    Post subject: Reply with quote
A direct chopped off rear (like a lorry or van) is pretty dire though. About a 50% taper seems to be accepted as a reasonable compromise between aerodynamics and weight / packaging, and likely than many coupes are close to this.
From an old article, a sphere has a Cd of about 0.45. A hollow sphre chopped in half with the hollow end facing the air flow has a Cd of about 1.4. A disk has a Cd of about 1.1. A teardrop shape has a Cd of about 0.05, while a reversed teardrop shape has a Cd of about 0.34. A wing section has a Cd of about 0.1~0.2.
Same article was playing around with a bit of bodywork coming up from behind the rider and over their back, fairing them in a bit (nothing done about the wheels, etc), using an early CBR600. Totally impractical for normal use. However that tail on the stock bike reduced the drag to 84% of the stock bike. With no bodywork at all the drag was 117% of the stock bike, and with no bodywork and the rider upright it was 134% of the stock bike.
Smooth
PostPosted: 10:14 - 08 May 2009    Post subject: Reply with quote
Kickstart wrote:
[A direct chopped off rear (like a lorry or van) is pretty dire though. About a 50% taper seems to be accepted as a reasonable compromise between aerodynamics and weight / packaging, and likely than many coupes are close to this.
Ive just found my uni lecturer's book on Google books, but the 2relevant pages are not shown!
"As the angle increases from zero (typical squareback) towards 15 degrees there is initially a slight drag reduction as the effective base area is reduced. ..." -I think he then went on to say that there is then an increase, until the angle is large. I remember a comment about many coupés being less 'aerodynamic' than the equivalent hatch/saloon/estate.
The chap in question did consultation for Indycar and Sports car racing teams.
TDM850
PostPosted: 10:54 - 08 May 2009    Post subject: Reply with quote
Most of the aerodynamic work on motorcycles is pissing into the wind until they make them with enclosed front wheels and stop putting riders on top of them.
PostPosted: 11:50 - 08 May 2009    Post subject: Reply with quote
Might depend on what you think of as a typical coupe then. I would consider then to be far closer to the horizontal at the back than 45 degrees, until they get to the cut off point.
1016
PostPosted: 12:48 - 08 May 2009    Post subject: Reply with quote
When I talked about research, I meant motorbikes... (as I think did OP) If we are including cars I had better reply when I have more time as although very rusty, a bit of a busman's holiday for me.
Meanwhile, does anyone have a (bike fairing related) practical answer for the layman yet?
Knacker
PostPosted: 12:53 - 08 May 2009    Post subject: Reply with quote
Im sure that once i read about this aerodynamics stuff and they compared a lambo to a VW camper and the camper came out on top ??? How the funk ?
Previous: K1 GSXR 1000
The last post was made 16 years, 271 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.02 - MySQL Queries: 13 - Page Size: 137.33 Kb
