| c-m |
 c-m World Chat Champion
| The Artist |
 The Artist Super Spammer
| McGee |
 McGee O RLY?
| 1016 |
 1016 Scooby Slapper
 Posted: 20:53 - 07 May 2009 Post subject: |
Good one.... Hope you get a big response 'cos any useful information (on this subject) can only really come from first hand experience, and (as you know) results vary so much from bike to bike. Only generalising here, I would guess sub-50mph additional weight of full fairings would lower MPG but if you were cruising at 80 upwards, then surely you would see a MPG benefit. I think you are the very man for the job of doing back-to-back tests and posting results!  |
| The Artist |
| chris-red |
 Posted: 22:11 - 07 May 2009 Post subject: |
Guy I know went out on a nitrous GSX1100 and went 164mph, put a fairing on it and went 191mph.
When you're looking for speed, aeros are everything! ____________________ a.k.a 'Geri'
 Posted: 22:28 - 07 May 2009 Post subject: |
Bikes are lousy at aerodynamics. Fairing help, but even a 'busa is pretty dire. It is aerodynamic drag and most of it comes from the back and no bike has even a vaguely clean rear end. The effort goes into the fairings as people think the fairing is important when it is really the back end that is more important.
For comparision my unfaired 1200 Bandit has about 25% more power than my faired Bimota. Through timing lights the Bandit is only a couple of mph faster.
Stability is funny. Might make a massive difference (either way). For a (car) example, the old Ford Sierra had stability problems early on. The fix was a tiny bit of trim sticking out about 1cm at most around the rear side windows.
| Tricolor |
 Tricolor Borekit Bruiser
| c_dug |
 c_dug Super Spammer
| c_dug |
 c_dug Super Spammer
 Posted: 23:31 - 07 May 2009 Post subject: |
meh, mines a D and ive never noticed it, i have it all the way up to 110mph and beyond on a pretty much daily basis so long as the weather and traffic allow.
Must just be an uber cool GPZ
c_dug ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| Scotsman37 |
 Scotsman37 World Chat Champion
| 1016 |
 1016 Scooby Slapper
| Smooth |
 Smooth Could Be A Chat Bot
| c_dug |
 c_dug Super Spammer
 Posted: 09:23 - 08 May 2009 Post subject: |
It would be almost impossible to make a vehicle in this shape but im 99% certain the most aerodynamic shape is the shape of a falling water droplet, i.e. large round frontal area and long drawn out rear working its way into a point, like so
 Posted: 09:34 - 08 May 2009 Post subject: |
Drag makes a difference at low speed, but the difference increases massively with speed. At 40mph a typical unfaired bike will need about 17 lbs of thrust to overcome aerodynamic drag while a 'busa will about 15 lbs of thrust.
To put that in perspective a restricted 6 speed Cagiva Mito in top gear at 40mph has about 41 lbs of thrust (and if using the gears and down in 3rd it would have a 110 lbs of thrust).
While you can improve aerodynamics it tends to add weight, which destroys acceleration. However the weight has very little effect on top speed (a very very marginal effect on rolling resistance). Think this is the basis for the kamm tail designs of cars, as although a full tapering rear is better, once you have started to gently reduce the height at the back you have gained most of the advantages. After that you are adding weight and length for a diminishing return. This is why coupes are shaped like that.
As I understand it a large vertical rear end is pretty dire for aeodynamics. Just look at how a conventional car shape will generally keep the rear window clear of rain when moving, where an estate will need a rear wiper to clear off all the water droplets sucked round onto it.
Tear drop is pretty perfect, and to an extent used in faired bikes for top speed attempts. Trouble is stability. It will move the centre of pressure far forward , well in front of the driving wheel and centre of gravity. Makes it like trying to throw a dart backwards.
| Smooth |
| Smooth |
| 1016 |
 1016 Scooby Slapper
| Knacker |
 Knacker World Chat Champion
The last post was made 16 years, 272 days ago. Instead of replying here, would creating a new thread be more useful? |
