missmatched tyres
chillpill
PostPosted: 17:43 - 08 May 2009    Post subject: missmatched tyres Reply with quote
any reason why this is a bad idea ? cheers
PostPosted: 18:21 - 08 May 2009    Post subject: Re: missmatched tyres Reply with quote
Because different tyre models and makes have different tyre profiles which means you could have a very soft gentle round profile on the rear, and a super sharp pointy profile on the front which will totally screw up your handling.
I've had a few bikes which have had mismatched tyres (when I bought them) and it hasn't really been an issue, but I wouldn't push my luck for the sake of a few quid if I was going to buy one tyre anyway.
SlimRick
PostPosted: 19:41 - 08 May 2009    Post subject: Reply with quote
Different levels of grip front and rear can never be a good thing.
Wozza
PostPosted: 22:02 - 08 May 2009    Post subject: Reply with quote
Why?
Paulington
PostPosted: 22:12 - 08 May 2009    Post subject: Reply with quote
Wozza wrote:
Why?
If you have more front end grip, then when you lean to take a corner, your front end will grip more than the back, which means if you turn sharp enough your front tyre will still grip while your back doesn't leading to a high/lowside.
PostPosted: 22:22 - 08 May 2009    Post subject: Reply with quote
You stand some chance of catching it when the rear slides. You stand pretty much zero chance of catching it if the front goes. Hence having the rear slide first tends to be safer.
Paulington
PostPosted: 22:25 - 08 May 2009    Post subject: Reply with quote
Yeah, and obviously the reverse will happen if you have more rear end grip, like having a Diablo Corsa on the back and a plastic tire on the front.
KevTM
PostPosted: 22:30 - 08 May 2009    Post subject: Reply with quote
I think this is more complex than, at least I, understand.
My thinking is that even with matched tyres the front & rear will have different grip levels at any given time, different loads on each tyre, etc etc.. Have you even lost both tyres at the same time? It's usually one or/then the other.
Perhaps that's why different tyres seem to work better on different bikes and/or for different riding styles?
To be honest I can't see there being much of a problem as long as you're not running completely different compounds, for instance, a hard/touring rear and a super soft front or something.
I could be completely wrong but surely there's some sense in there Laughing
Wozza
PostPosted: 23:09 - 08 May 2009    Post subject: Reply with quote
Pretty much what I was thinking.
Having a softer front tyre won't make the rear tyre have any less grip than normal, that's just daft. If you've got a crappy plastic tyre on the back, it's gonna slip no matter what you've got on the front.
I know of people who purposefully mismatch tyres to get a better lifespan out of the rear by sacrificing a little bit of grip, but keeping a softer tyre on the front.
For example:
Bridgestone BT-090 front, BT-92 rear.
Or Michelin Pilot Power front, Pilot Road 2 rear.
I wouldn't want to mismatch any old tyres, but thought-out mismatching is not uncommon.
Paulington
PostPosted: 23:55 - 08 May 2009    Post subject: Reply with quote
I didn't say it would, I said the front would have more grip, and therefore while it would still grip comfortably, the back tyre if it is a bit harder will slide on heavy cornering. It'd only be noticeable if you were pushing it though.
However, to keep the thread going in the intended direction..
My bike, going to lean into a corner it feels as if it doesn't want to lean, and when it does lean it feels as if the front end is going to drop away.
Any clues?
Eddie Hitler
PostPosted: 23:58 - 08 May 2009    Post subject: Reply with quote
Any clues?
Yea, you ride a shitty bike and think you know everything about motorbikes.
Paulington
PostPosted: 00:02 - 09 May 2009    Post subject: Reply with quote
Eddie Hitler wrote:
Any clues?
Thanks. Laughing.
If I thought I knew everything, I don't think I'd be asking a question about my bike now would I? Thumbs Up.
Eddie Hitler
PostPosted: 00:03 - 09 May 2009    Post subject: Reply with quote
Current Bike: Aprilia RS50 '06.
Top speed: 75 mph
Paulington
PostPosted: 00:06 - 09 May 2009    Post subject: Reply with quote
Top speed: 75 mph
Haha don't start this again, it happens in every thread I post in.
If you want to bemoan and berate about it then do so in a PM rather than ruin a thread. Rolling Eyes.
Eddie Hitler
PostPosted: 00:18 - 09 May 2009    Post subject: Reply with quote
What do you expect.
lukamon
hes got a point though. 75mph? my c90 does 60mph Rolling Eyes
killa wrote: Im an ass man myself
Ben.
PostPosted: 00:36 - 09 May 2009    Post subject: Reply with quote
depends what your mixing...
ive got a 2ct rear and a diablo corsa front, both got more than enough grip to get rid of any chicken stips, both heat up at about the same pace, and neithier will overheat on the road, so its fine. However i had a shitty michilin rear before i got the 2ct and that would over heat, and suddenly let go mid corner, the front would stay planted but the rear would slip, if your going to mix, allways get a grippier front, or get tyres that are of similar grip that you know you cant over heat...
follow my racing season
Race bike - R6
Road bike - sv650
Paulington
PostPosted: 00:39 - 09 May 2009    Post subject: Reply with quote
Malossi kitted RSes can do 100+ but only for about 15 minutes, mine is a reported 50cc cylinder, custom pipe, new carb and airbox + slipstreaming behind my Dad's bike.
Blah blah whatever, if you doubt it fair enough but if you want to debate it don't 'jack a thread to do it.
Ben.
PostPosted: 00:44 - 09 May 2009    Post subject: Reply with quote
just ignore them, you look like just as much as a tit as them when you reply to them...
Race bike - R6
Road bike - sv650
Eddie Hitler
PostPosted: 00:50 - 09 May 2009    Post subject: Reply with quote
Bets on how long you take to reply to this then. Mr. Green
keyser soze
PostPosted: 01:14 - 09 May 2009    Post subject: Reply with quote
I think it all depends on what your riding where and and how.
for me, I ride a supermoto and I like the most grip I can at the front and less at the back. its great when riding normaly but when I get going its brilliant fun sliding the back
iooi
PostPosted: 08:45 - 09 May 2009    Post subject: Reply with quote
I point you to a Moto Gp bike where they tend to drift the rear round the corners......
Its all about rider control and knowing just what the limits are.
The biggest No No's are cross ply and radial mix's
garth
PostPosted: 10:10 - 09 May 2009    Post subject: Reply with quote
I like having a crap tyre on the back, it's fun Mr. Green
PostPosted: 18:29 - 09 May 2009    Post subject: Reply with quote
I would say that grip and handling are 2 different things. Sometimes you land up with both.
Sometimes (most of the time I would say) mixing different tyres wil be fine in normal use. Riding at the very limit probably not perfect, but then very few have the ability to really ride at that limit.
As to your handling issue with the RS50, first thing I would say to check would be the tyre pressures. Tyre wear can also have odd effects. A worn front tyre can often give the same handling as a front tyre that is low on pressure (ie, when you start to lean the bars want to turn into the corner).
Joeb46
PostPosted: 22:24 - 10 May 2009    Post subject: Reply with quote
i have odd tyres and i still managed to get my knee down today, not big or clever on a drz Neutral but never mind, something to tick off the list Mr. Green
Current- Drz400sm- For sale
Kawasaki er-5 race bike# 106
The last post was made 17 years, 127 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 138.32 Kb
