cbr600ft jack up kit
flyingmythos
PostPosted: 22:09 - 23 Apr 2009    Post subject: cbr600ft jack up kit Reply with quote
Hi, new member here, got myself a cbr6 (off ebay) and need to raise the back end, I have seen the dog bones for other bikes but what does a cbr600ft need, as it hasn't got them
lonner
PostPosted: 22:37 - 23 Apr 2009    Post subject: Re: cbr600ft jack up kit Reply with quote
if its like most hondas ive owned its a case of fitting a spacer above the rear shock mount hth
flyingmythos
PostPosted: 18:06 - 08 May 2009    Post subject: Reply with quote
Thanks, I will have a look into that, got to find out why the engine is so rattly before I do anything else.
mad4it028
PostPosted: 18:20 - 08 May 2009    Post subject: Reply with quote
being a cbr600 the rattle will probally be the cam chain tensioner easy job
flyingmythos
PostPosted: 18:39 - 08 May 2009    Post subject: Reply with quote
How easy a job is it? and is there any way of checking it is that before spending time and money on it? only rattles between 3-5k and sometimes on tickover.
mad4it028
PostPosted: 18:52 - 08 May 2009    Post subject: Reply with quote
2 bolts and about 5mins of your time that easy
flyingmythos
PostPosted: 18:55 - 08 May 2009    Post subject: Reply with quote
That sounds to easy, I take it the 2 bolts hold the tensioner in place, can I test it when removed? or can I just adjust it? will anything nasty fall inside when I take it out? only ever worked on singles, its all new to me.
mad4it028
PostPosted: 20:21 - 08 May 2009    Post subject: Reply with quote
sorry dont know how you can test it but you should be able to tell by the rattle if its cam chain rattle which is a common fault with the cbr and normally turns out to be the tensioner
nothing will fall ouyt when you unbolt it
flyingmythos
PostPosted: 20:28 - 08 May 2009    Post subject: Reply with quote
Thanks, I have just downloaded a manual and will have a go tomorrow, thanks again.
mad4it028
PostPosted: 17:36 - 11 May 2009    Post subject: Reply with quote
how did you get on?
flyingmythos
PostPosted: 08:30 - 17 May 2009    Post subject: Reply with quote
As the rattle isn't all the time I have decided to leave it for now, the fairing is due to come off soon when I streetfighter it so will have a go then, thanks.
mad4it028
PostPosted: 08:51 - 17 May 2009    Post subject: Reply with quote
you dont need to remove the fairing to change it
PostPosted: 09:41 - 17 May 2009    Post subject: Reply with quote
If you raise the back end on an already quick turning bike you'll end up making it very very very unstable and slap happy.
If you HAVE to do it, then I reccomend fitting a steering damper.
flyingmythos
PostPosted: 20:03 - 18 May 2009    Post subject: Reply with quote
I have been advised to get a manual cct now, just can't find 1 in the UK, I have sent my bar risers off to be bored out to 41mm though so i can fit my straight bars, then its off with the fairing.
flyingmythos
PostPosted: 21:47 - 30 May 2009    Post subject: Reply with quote
I took the cct out and messed with it, put it back in with the spring fully wound then released it, started the bike and it was sweet! for about 5 minutes, rattle is back now but more prominent, would a new cct solve this or does it need cam chain doing? on 35k, ben offered a manual one, would that just strain the chain?
PostPosted: 22:21 - 30 May 2009    Post subject: Reply with quote
Manual ones are loads of hassle. Just buy a new standard one from Honda.
mad4it028
PostPosted: 22:22 - 30 May 2009    Post subject: Reply with quote
i opened up my cct and added a stronger spring mine never rattled again and was fine 10000 miles later when i sold it
i looked into the maual cct but decided that it would be far to easy to do major damage over/under adjusting so just modified a standard 1 as its is a common cbr problem
flyingmythos
PostPosted: 22:27 - 30 May 2009    Post subject: Reply with quote
But my cct had reached its max I think, unscrewed it a few times and measured the screwdriver, seems the same when fitted?
flyingmythos
PostPosted: 22:28 - 30 May 2009    Post subject: Reply with quote
where did you get the spring from? or did you just stretch the one fittted?
mad4it028
PostPosted: 22:32 - 30 May 2009    Post subject: Reply with quote
i used an exhaust spring off a pug 106 i think it was ,
it fitted over the standard spring so had both springs in there
flyingmythos
PostPosted: 22:45 - 30 May 2009    Post subject: Reply with quote
so you think a stronger spring will do it? I shall try that tomorrow, I must av a spring somewhere, but surely the chain must be stretched to need more pressure? and why would my rattle be worse after freeing it up? hope it is the chain, just spent 2 hours cutting the fairing up to fit straight bars!!!
The last post was made 17 years, 101 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 107.58 Kb
