| Slimboyfat |
 Slimboyfat Two Stroke Sniffer
 Posted: 20:01 - 03 Apr 2002 Post subject: Gear Changing, without clutch?...... |
Wierd i know, but some of my work mates have 600cc bikes and i was chatting about changing gears at speed and they said most of the time you can just ease off the throttle, go up a gear(no clutch), back on throttle and it is ok. Now call me old fashioned but isn't that what the clutch is for.......? Please help as I am getting a new nsr soon and i am major confused!
| Maple |
 Maple Guest
 Posted: 20:13 - 03 Apr 2002 Post subject: Slimboy Fat |
Is this for road use or for track? If its for road there is not much point. If its for track its best you get a quick shift fitted (on a 600). If you are thinking of doing this on the road on a 125 it wont be long before you knock the cogs off .. a 2 stroke revs more and you will ruin the box. The 600 guys are obviously on a four stroke and the engine dies quicker so you get less revs at the time of shutting off. Your thinking is right, the clutch is there for a purpose. One of my friends used to do this, he timed it just right in speed to change gear and then wondered why he knackered the box. So my advice is a BIG NO NO!  |
| Phil. |
 Phil. World Chat Champion
 Posted: 20:13 - 03 Apr 2002 Post subject: no clutch |
Motor cross riders do that alot, i tried it on my NSR a few times but it never seemd to go in a smoothly as it would using the clutch.
Keep usin your clutch, better safe than sorry. But if you give it a try, dont do it when changing down.. not unless you want a new gear box  |
| Slimboyfat |
| Maple |
 Maple Guest
 Posted: 20:56 - 03 Apr 2002 Post subject: No Clutch |
Well...
Let it run for a bit first to get the temp up a bit. 2-strokes dont like ticking over very much cos they choke up. Without putting it to harsh they like to be run hard. One thing you will notice is when you change down the bike will still run on .. changing down will not act like a brake. Whereas a four stroke will shut off when you change down. You will soon get used to it. Its not hard, Christ if I can ride one anyone can.
Suppose the quicker you can get it off choke the better. Once its off choke it will run smooth. Good Luck and have fun.  |
| G |
 G The Voice of Reason
 Posted: 22:07 - 03 Apr 2002 Post subject: no clutch |
I've been using clutchless shifts fairly regularly for the (on and off) five years I've been riding. I've read in various sources that clutchless shifting can actually be better for your engine *if* you get it right... The idea being that the gears don't have to mesh at all becasue they snick straight into place.
I've used clutchless shifting on my NS & NSR and not had any problems, the only engine I've killed was my KLR and that's mostly to do with 40,000 miles and too many unskilled wheelies .
Once you get some practice you can do it up without any hassle and pretty smoothly down as well.
The way I do it is to put a very light upwards force on the gear lever, then dip the throttle. The gear should change at the right point without any further input. Once you get used to it you can put a bit more pressure on the lever and dip the throttle a bit less. |
| McJamweasel |
 McJamweasel BCF Junkie
| TiN |
 TiN Pocket Tin
| TJ NSR |
 TJ NSR World Chat Champion
| DrSeuss |
 DrSeuss Two Stroke Sniffer
| Dylan |
 Dylan Trackday Trickster
There is a gap of 2 years, 54 days between these two posts... |
| clemsta |
 clemsta Scooby Slapper
| numark1 |
 numark1 Scared of girls
 Posted: 14:45 - 29 May 2004 Post subject: |
I always change gears without using the clutch when doing motocross mainly because you if you take your hand of to reach for the clutch then you have less control of the bike and its slower. Not by much but in motocross like every other motor sport if it takes a second of your lap time then it has to be worth it. My crosser is a 2 stroke and i always use clutchless gear changes and it still runs fine. I'm not sure if it does affect the gearbox/engine or not.
Hope this helps  |
| Milo |
 Milo World Chat Champion
 Posted: 14:48 - 29 May 2004 Post subject: |
I can change up really smoothly through all the gears on my XJ900
Ads ____________________ Shaft drives rule.  |
| MarJay |
 MarJay But it's British!
 Posted: 17:52 - 29 May 2004 Post subject: |
Clutchless changes are noticeably faster on powerful bikes (600+) if you get them right!
Probably not woth the bother on an NSR though.  ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
Remember kids, bikes aren't like lego. You can't easily take a part from one bike and then fit it to another. |
| mrchips |
 mrchips World Chat Champion
| Milo |
 Posted: 18:06 - 29 May 2004 Post subject: |
Sorry for my earlir short post - I was in a rush.
I don't keep constant pressure upward on my gear lever, but maybe I'll give that a go.
I instead get to the point I want to change, dip the throttle so it puts less stress on things and change up. So hard to get out of the habbit of using a clutch though!
On my bike I'd only change up without using the clutch above about 4k. ____________________ Shaft drives rule.  |
| ezj |
 ezj L Plate Warrior
 Posted: 19:26 - 29 May 2004 Post subject: Agree |
I have to agree...
Theoretically I always thought clutchless changing must be bad news for the bike, but I had an NS125R and used to do it all the time. It was certainly quicker and it never ever caused me a problem (I had the bike tuned and rode it commonly like this for a number of years).
I wouldn't recommend it though, I just didn't care in them days  |
| The Dude |
 The Dude Crazy Courier
| BiKeBiKeBiKe |
 BiKeBiKeBiKe Borekit Bruiser
| bikegirl |
 bikegirl Nitrous Nuisance
 Posted: 22:51 - 29 May 2004 Post subject: |
I wouldn't try clutchless down at all, you may knacker the gearbox.
To change up start by holding your hand over the clutch and just pressing it in slightly with your 1st 2 fingers so it doesn't engage. This will ensure that you've got the revs in the usual state for a gear change - it's too easy to botch it when you're trying something new. Try it a few times like this to get used to the idea of not engaging the clutch, then try it without pressing.... then onto "look no hands". If you botch it then start again - you'll get used to it.
It's cool on the road and very useful on the track.
Susie ____________________ www.bikegirl.co.uk |
| mr.z |
 mr.z World Chat Champion
 Posted: 23:07 - 29 May 2004 Post subject: |
Down changes are tricky at the best of times, up cahnges on any bikes ive ridden have been realtively easy if your doing it right, but don't worry about it too much for now... and if your unsure of it don't.
Lets put it this way.
Clutch plates are £30/40,
Gear boxes on even a cg125 will set you back £500 a bike that you can buy for £600 or less... biger bikes are seriously more expensive, pritty much a gaurenteed write off i'd imagine.
I think its the selector forks wich take the majority of the mashing, even then its a long job and engine out and apart, even without parts your looking at hundreds in labour costs alone!
The gains are minor but it is cool when you do it right, like bliping on downchanges, matches the engine speed to the wheel speed and reduces the risk of spining out on a harsh downchange and is better for your engine, with a beastly 50bhp at my command its not really a likely problem neither would it be on a 125, but... it sounds cool  ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| Visitor Q |
 Visitor Q $25 whore
 Posted: 09:27 - 30 May 2004 Post subject: |
There are problems with it though.
Upchanging i just snap off the throttle and smack it up and in as normal (just gotta have a tad more pressure when u do it)
Down ARENT good and you risk very harsh engine braking, but if you want to, just let the revs drop lots, like on your nsr from like 9k to 4k and click it down, just dont do it atrevs you will get engine braking (and you get engine braking on 2t's too, enough to lock up.
Ps on light bikes (like my goose, and varius other bikes i do the odd bit of clutchless) if it doesnt go in you will find youve just kicked you bike basically, and it goes most unstable for a second, this i why i just leave it for when im lazy of the crappy gooses clutch has broke my hand.
Wouldnt advise it in overtaking till you get good with your bike, cock ups mid overtake cost lifes or at least pride ____________________ China traffic/travel bike vid - When I make a sweeping statement, please add the word 'statistically' in to the sentence before you bitch...
From September 2014 to January/February 2015 I will not be using any English, nor reading any. As such, I won't be on here. PM at will, but I won't be checking/posting unless in emergencies. Certainly not for the first couple of months. Please berate me savagely if I break that rule... |
| BiKeBiKeBiKe |
This post is not being displayed because it has a low rating (Confusing). Unhide this post / all posts.
| Robby |
 Robby Dirty Old Man
The last post was made 21 years, 255 days ago. Instead of replying here, would creating a new thread be more useful? |
