| Mr Hammers |
 Mr Hammers World Chat Champion
 Posted: 10:53 - 09 May 2009 Post subject: Broke brake |
DON'T forget the disclock....DON'T forget the disclock...DON'T forg......oops..forgot the disclock....
https://www.planetash.net/bcf/brokenbrake.jpg
Can't believe I did it *again*. Second time now, but this time I managed to snap the caliper arm at the back and the end of the speedo cable. Going to try and see if I can find just the bit that broke, but I suspect I'm going to have to buy a whole new caliper.
Someone, please, just... just shoot me... ____________________ A Guide To Powerbands |
| ms51ves3 |
 ms51ves3 Super Spammer
| Faraz |
 Faraz Nearly there...
 Posted: 11:53 - 09 May 2009 Post subject: |
 ____________________ '56 Yamaha MT-01
'05 Nissan 350z Roadster GT
3 words dude.. Fvck. Yes. |
| johnsmith222 |
 johnsmith222 World Chat Champion
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 13:45 - 09 May 2009 Post subject: |
could have been worse.... it could have cracked off at the forks. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| DEN MONKEY |
 DEN MONKEY World Chat Champion
 Posted: 16:44 - 09 May 2009 Post subject: |
did it twice myself but luckily just rolling the bike back and broke 2 fenders. the second one was only 2 weeks after I did it the first time and replace it.
Don't use a disc lock anymore  ____________________ meh |
| Finglonga |
 Finglonga World Chat Champion
| Mr Hammers |
 Posted: 18:40 - 09 May 2009 Post subject: |
Thought my luck was in..rang the local Suzi dealer to see how much a new err...'bit' (still don't know the actual name of it) would cost...jaw hit the floor when he told me that they're £60. £60 for a piece of cast ally..??
But, then he said there was someone in the shop who happened to have calipers that would fit and wanted £50.00. Great! I thought. So went and got them, just got back and surprise surprise...it doesn't fit. I can't even use the whole caliper assembly as the fork boltholes are totally different.
That said, he does have the rest of the bike (GSXR 750) for sale for £100. It's pretty tatty, but the forks are adjustable (and I assume much better than standard Bandit ones..?) so I could get that, rob the forks off it and use the calipers.
But that'll take time, and I'm already gutted that I won't be able to use it for at least a few days next week.
If anyone has a set of Bandit calipers, or even just that bit, please let me know!
| ms51ves3 wrote: | You need a bit of tubing.
Put it over your ignition key when you put your disc lock on, then you can't forget. When it's not over your ignition key, put it over your disc lock key so it doesn't scratch your top yoke. |
That is a really good idea. Think I might try that!  ____________________ A Guide To Powerbands |
| MaybeGuy |
 Posted: 18:58 - 09 May 2009 Post subject: |
you do realise it would be so easy to ally weld that back up? they would probably charge you a 5er, then you could file it all down and not be able to tell the difference. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Mr Hammers |
| BanditsHigh |
 BanditsHigh Worse than a woman
 Posted: 09:20 - 10 May 2009 Post subject: |
It is possible to weld cast ally, but I don't think I would on a brake part  |
| truslack |
 truslack World Chat Champion
 Posted: 17:25 - 10 May 2009 Post subject: |
I once managed to snap a disk lock in 2 on my RS50 when I forgot it was on. I don't have these problems on the 500... it has drum brakes front and back  ____________________ Current: Suzuki RG 125 Gamma, Honda H100, Triumph Tiger 800XC, Suzuki SV650 (minitwin) |
| Mr Hammers |
| ajb |
 ajb Crazy Courier
| Noxious89123 |
| Mr Hammers |
 Posted: 23:10 - 10 May 2009 Post subject: |
| Noxious89123 wrote: | | Mr Hammers wrote: | Well, the part itself isn't load bearing as such, I think, it's not under strain while braking at all (at least, not in the same way that it snapped) |
Of course it's "load bearing", it's attached to the caliper stops it fulying off at warp speed when you apply the brakes!  |
I mean the stress of that particular part (and I'm not 100% sure of this, I should add) is that the stress isn't where the breakage is. It only broke there because it's not designed to have a disclock hit it.
I had a good look when I took it off tonight, and it looks like the pressure of braking would have the effect of actually pushing the two pieces together, rather than apart. All a weld would need to do is to make sure it didn't move.
Ohh, I don't know. I'm already having second thoughts about welding it now (thanks, BanditsHigh ........ ) so I might not bother now anyway. Just use the car (shudder) until I get a decent replacement part. ____________________ A Guide To Powerbands |
| MaybeGuy |
 Posted: 23:13 - 10 May 2009 Post subject: |
if its ally welded, it will be near enough the same strength as the original material.
the material used is always well in excess of what is required anyway. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Mr Hammers |
| MaybeGuy |
 Posted: 14:38 - 11 May 2009 Post subject: |
ideal. now file it down so it doesnt look like a slug. as long as the penitration is ok, it wont compromise the strength. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
The last post was made 17 years, 172 days ago. Instead of replying here, would creating a new thread be more useful? |
