| cheesyleps |
 cheesyleps Renault 5 Driver
| 5v3d3b0 |
 5v3d3b0 World Chat Champion
| Ichy |
 Ichy World Chat Champion
 Posted: 00:10 - 11 May 2009 Post subject: |
If it generally looks in reasonable condition then the first thing I always do is attach a battery and try to start it, its not likely to have much wrong with it after 14 months, a lot of new cars sit in fields for longer than that
Once it starts I would change the oil then go for a short ride to see if anything else is needed. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| cheesyleps |
| Bendy |
 Bendy Mrs Sensible
| b-f-c |
 b-f-c Traffic Copper
| Pete. |
 Pete. Super Spammer
 Posted: 10:58 - 11 May 2009 Post subject: |
It'll probably take enough cranking to start it to do that anyway.
It'll need a new battery, charging the old one is a waste of effort as even if it takes a small charge it'll have no real capacity and will die very soon anyway. I would chack the oil level then crank here over and listen for any horrible noises before spending any money on it. If it sounds ok then give it a good going-over.
Be prepared for a couple of good days maintenance at least. ____________________ a.k.a 'Geri'
| Blue_SV650S |
 Blue_SV650S World Chat Champion
 Posted: 10:59 - 11 May 2009 Post subject: |
Drain the tank of old yucky fuel*, stick some fresh fuel in there, get some jump leads form the car and whirl her over!!
If you are lucky, it'll run fine and all you need is a new battery for it, if you are less lucky it'll need a carb strip and clean ....
*or at a minimum 'brim' the tank to dilute the old sh1tty petrol in there. ____________________ The purpose of life is to fight maturity. |
| 1016 |
 1016 Scooby Slapper
| map |
 map Mr Calendar
| Blue_SV650S |
 Posted: 11:36 - 11 May 2009 Post subject: |
| Ichy |
| Robby |
 Robby Dirty Old Man
| Kickstart |
 Kickstart The Oracle
 Posted: 13:07 - 11 May 2009 Post subject: |
Another vote for just starting it.
The ZZR600 does seem to need a fair amount of battery power before it will idle. Probably worth taking the battery off and putting it on an optimate for a few days. It might well be dead long term, but at least should have enough power to let the bike idle.
Would be inclined to think about draining the petrol (or most of it) and then putting fresh petrol in.
If you want to crank it over for a bit without it starting the I would just short out the starter relay rather than faffing round disconnecting things.
| 1016 |
 1016 Scooby Slapper
 Posted: 00:07 - 12 May 2009 Post subject: |
my first post did have some ambiguity in it, so I will try again... :-
On a popular Kawasaki forum several owners had posted saying that they had burnt out ignition components on their bikes (similar to ZZR600) by cranking over continuously with spark plug caps REMOVED - i.e. nowhere for the spark to ground - warnings of same in Haynes and factory handbook.. Is that better? P.S. If you are going to crank an engine just to try and clean up bores in preparation for starting after long layup, then plugs out/squirt of oil method is best everytime - easier on starter, easier on battery  |
| Kickstart |
| Blue_SV650S |
| 1016.5 |
 1016.5 Renault 5 Driver
| Wozza |
 Wozza Brolly Dolly
The last post was made 17 years, 153 days ago. Instead of replying here, would creating a new thread be more useful? |
