Tyre change solution?
Itchy
PostPosted: 20:42 - 11 May 2009    Post subject: Tyre change solution? Reply with quote
Find me a solution to my problem here,
I had to change the tube on the XT600E , which meant I had to tip it on its side and struggle to remove the rear wheel as you need to undo things on both sides. I did this on the motorway at 3am a markedly unpleasant experience. Took me an hour as I couldn't see jack.
A centre stand is £££££ heavy and also means very little ground clearance the centre stand for sale from metal mule is also rated at just the bike's weight and there are horror stories of them bending with luggage on the bike.
Tipping it over is the cheap but uneasy option in that tipping it over spills petrol and you have to remove either the brake lever or the gear shifter else they bend into the engine.
What solutions do you have that ful fil the following criteria:
Not expensive
Weigh less than 2.5 kilos
Will fit into the space of half a show box..
I've had limited sucess with car jacks.
What are you solutions BCF?
EDIT
I am not strong enough to let the bike rest on its swing arm and to lift it up and slot the wheel in either.
Scouse
PostPosted: 20:47 - 11 May 2009    Post subject: Reply with quote
https://www.tradenote.net/images/users/000/442/702/products_images/Electric_Car_Jack__Electric_Hoisting_Jack__Hydraulic_Jack.jpg
yen_powell
PostPosted: 20:53 - 11 May 2009    Post subject: Reply with quote
There's a rod thing sold by the likes of M&P/Busters/MPS that is used with the sidestand and swingarm. Looks the same as me using an axlestand under the footrest hanger plus sidestand on my DR (and AT sometimes) when I want to remove one of the wheels or oil the chain.
https://www.geocities.com/MotorCity/Downs/6164/page40.html
https://www.stowektm.co.uk/motionpro.htm
XT1200Z and a DR350 in bits
PostPosted: 20:56 - 11 May 2009    Post subject: Re: Tyre change solution? Reply with quote
For the older LC4 KTMs, I've seen some with bash-plates that double as a centre-stand. Seems an ideal solution as the weight/strength is in something already required.
Otherwise, surely some kind of mini-axle stand to lift the right hand side of the bike up? Think you had a hard-top box - if so, could you use that somehow to lift the bike up a bit, maybe with something else on top?
Itchy
PostPosted: 21:03 - 11 May 2009    Post subject: Re: Tyre change solution? Reply with quote
Nope top box is coming off , I came back to reconfigure the bike as it was too much of a wind magnet for buffetting , soft side paniers are staying though.
Handsome
PostPosted: 21:34 - 11 May 2009    Post subject: Reply with quote
Get a rack for the back...
Buy a cheap paddock stand, cut into sections, drill said sections, buy bolts for said ' said ' sections...
Keep two spanners along with modified paddock stand and bolts in a bag attached to rack that's now mounted on the bike...
Re-assemble paddock stand as and when needed...
I'm thinking aloud so Meh if you don't like it...
... Thumbs Up
Wozza
PostPosted: 22:59 - 11 May 2009    Post subject: Reply with quote
1) Ratchet strap
2) Tree*
*I advise finding a tree near your next breakdown point rather than carrying one.
PostPosted: 23:29 - 11 May 2009    Post subject: Reply with quote
Two bits of box section, one that fits inside the other. Weld a U-shaped gutter on the top of one that slots neatly onto the swingarm.
Slide one inside the other then extend them until they are the correct length so you can push the bike over towards the sidestand far enough to just lift the rear wheel off the ground and slip the bits of box section under the swingarm. Now mark and drill a hole that passes through both bits of box section at this point and put a bolt through them.
You now have a collapsable rear wheel prop-stand that will fit under the saddle.
If you make it extend to a different length by means of another hole for the bolt, it is entirely possible to use it in the same way under the front part of the frame to remove the front wheel too.
A mate of mine toured Australia on a KLR650 and changed tyres using this exact technique.
EDIT: For extra space-saving, you can fit about three spanners inside the collapsed bits of box section.
Itchy
PostPosted: 07:15 - 12 May 2009    Post subject: Reply with quote
Good idea but I cant weld.
Itchy
PostPosted: 07:20 - 12 May 2009    Post subject: Reply with quote
Discontinued unfortunately
yen_powell
PostPosted: 08:53 - 12 May 2009    Post subject: Reply with quote
Make one, it's only a piece of tube. My mate made one for his DR440 that actually bolted to his swing arm. I never looked too closely cos he wouldn't shut up about how wonderful it was and I didn't want to start him off again.
Itchy
PostPosted: 21:05 - 12 May 2009    Post subject: Reply with quote
Whey ! I found a very simple solution to this....
A hammer with rubber coated handle... just had a go wedging one under the swing arm and also wedging it under the bash plate and it works.
Completely conveniently it is nice to hammer in my separate sharpened tube pegs for my tent and also to (gently) tap out my rear spindle .....actually that makes no sense at all in that if I use a hammer under the swing arm then I can't be using it to tap out the smegging spindle can I Doh!
Will probably get a slightly lighter hammer at a local store to save some weight on this.
Although it does weigh more than I would like but can't have everything.
The last post was made 16 years, 286 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.61 - MySQL Queries: 13 - Page Size: 81.51 Kb
